<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PTR settings incorrect after switching VPS provider]]></title><description><![CDATA[<p dir="auto">I switched hosting of my VPS from DigitalOcean to Google and now my PTR record is incorrect. Any tips on how to correct this?</p>
<p dir="auto"><img src="/assets/uploads/files/1601024399057-screenshot-2020-09-25-at-09.59.10-resized.png" alt="Screenshot 2020-09-25 at 09.59.10.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.cloudron.io/topic/3214/ptr-settings-incorrect-after-switching-vps-provider</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 06:00:01 GMT</lastBuildDate><atom:link href="https://forum.cloudron.io/topic/3214.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Sep 2020 09:01:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PTR settings incorrect after switching VPS provider on Tue, 20 Jul 2021 00:05:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/christiaan" aria-label="Profile: christiaan">@<bdi>christiaan</bdi></a> On linode, if you are a new account, you can usually open a support ticket and explain your use case of email hosting to them and they usually unblock port 25.</p>
]]></description><link>https://forum.cloudron.io/post/34107</link><guid isPermaLink="true">https://forum.cloudron.io/post/34107</guid><dc:creator><![CDATA[girish]]></dc:creator><pubDate>Tue, 20 Jul 2021 00:05:56 GMT</pubDate></item><item><title><![CDATA[Reply to PTR settings incorrect after switching VPS provider on Sun, 18 Jul 2021 06:05:35 GMT]]></title><description><![CDATA[<p dir="auto">@hillside502 This might be as good a time as any to open a thread sharing which hosts we all use.</p>
]]></description><link>https://forum.cloudron.io/post/34034</link><guid isPermaLink="true">https://forum.cloudron.io/post/34034</guid><dc:creator><![CDATA[scooke]]></dc:creator><pubDate>Sun, 18 Jul 2021 06:05:35 GMT</pubDate></item><item><title><![CDATA[Reply to PTR settings incorrect after switching VPS provider on Sat, 17 Jul 2021 21:16:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scooke" aria-label="Profile: scooke">@<bdi>scooke</bdi></a> said in <a href="/post/34030">PTR settings incorrect after switching VPS provider</a>:</p>
<blockquote>
<p dir="auto">...you'll have to switch to VPS that allows it.</p>
</blockquote>
<p dir="auto">such as Time4VPS<br />
<a href="https://www.time4vps.com/linux-vps/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.time4vps.com/linux-vps/</a></p>
]]></description><link>https://forum.cloudron.io/post/34033</link><guid isPermaLink="true">https://forum.cloudron.io/post/34033</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sat, 17 Jul 2021 21:16:11 GMT</pubDate></item><item><title><![CDATA[Reply to PTR settings incorrect after switching VPS provider on Sun, 18 Jul 2021 06:05:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/christiaan" aria-label="Profile: christiaan">@<bdi>christiaan</bdi></a> Linode blocks port 25 too? I hate to say this, but if you really want this, you'll have to switch to a VPS that allows it.</p>
]]></description><link>https://forum.cloudron.io/post/34030</link><guid isPermaLink="true">https://forum.cloudron.io/post/34030</guid><dc:creator><![CDATA[scooke]]></dc:creator><pubDate>Sun, 18 Jul 2021 06:05:00 GMT</pubDate></item><item><title><![CDATA[Reply to PTR settings incorrect after switching VPS provider on Sat, 17 Jul 2021 12:53:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/girish" aria-label="Profile: girish">@<bdi>girish</bdi></a> I've realised I do care about this. I've since changed to Linode and have the same problem. Does the same solution apply as GCE? Set up a relay?</p>
]]></description><link>https://forum.cloudron.io/post/34029</link><guid isPermaLink="true">https://forum.cloudron.io/post/34029</guid><dc:creator><![CDATA[christiaan]]></dc:creator><pubDate>Sat, 17 Jul 2021 12:53:43 GMT</pubDate></item><item><title><![CDATA[Reply to PTR settings incorrect after switching VPS provider on Mon, 19 Oct 2020 17:27:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/christiaan" aria-label="Profile: christiaan">@<bdi>christiaan</bdi></a> For nextcloud, the calendar app does send your reminders by email for events (there are some options when you create an event). But if you don't care about that, you can ignore the PTR warning.</p>
]]></description><link>https://forum.cloudron.io/post/16345</link><guid isPermaLink="true">https://forum.cloudron.io/post/16345</guid><dc:creator><![CDATA[girish]]></dc:creator><pubDate>Mon, 19 Oct 2020 17:27:37 GMT</pubDate></item><item><title><![CDATA[Reply to PTR settings incorrect after switching VPS provider on Mon, 19 Oct 2020 17:24:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/girish" aria-label="Profile: girish">@<bdi>girish</bdi></a> thanks guys. All I currently have is a simple HTML website and Nextcloud running for calendars and contacts, so I probably don't even need to the server to send email, right? In which case I just ignore the PTR warning.</p>
]]></description><link>https://forum.cloudron.io/post/16343</link><guid isPermaLink="true">https://forum.cloudron.io/post/16343</guid><dc:creator><![CDATA[christiaan]]></dc:creator><pubDate>Mon, 19 Oct 2020 17:24:08 GMT</pubDate></item><item><title><![CDATA[Reply to PTR settings incorrect after switching VPS provider on Fri, 25 Sep 2020 18:39:28 GMT]]></title><description><![CDATA[<p dir="auto">On GCE, you cannot send email directly from the server. They block outbound port 25. See <a href="https://cloud.google.com/compute/docs/tutorials/sending-mail/" target="_blank" rel="noopener noreferrer nofollow ugc">https://cloud.google.com/compute/docs/tutorials/sending-mail/</a> . This means you have to set a mail relay for the server to send email. When you set an email relay, the PTR setup is not required.</p>
<p dir="auto">So, the correct fix for your problem is to setup a relay and ignore the PTR warning for now.</p>
]]></description><link>https://forum.cloudron.io/post/13686</link><guid isPermaLink="true">https://forum.cloudron.io/post/13686</guid><dc:creator><![CDATA[girish]]></dc:creator><pubDate>Fri, 25 Sep 2020 18:39:28 GMT</pubDate></item><item><title><![CDATA[Reply to PTR settings incorrect after switching VPS provider on Fri, 25 Sep 2020 09:29:08 GMT]]></title><description><![CDATA[<p dir="auto">Actually we do not have docs about how to do this with Google VPS provider. <a class="plugin-mentions-user plugin-mentions-a" href="/user/christiaan" aria-label="Profile: christiaan">@<bdi>christiaan</bdi></a> if you figure that out, maybe you could make some screenshots and let us know how to do that in Google and we will add it to the docs.</p>
]]></description><link>https://forum.cloudron.io/post/13653</link><guid isPermaLink="true">https://forum.cloudron.io/post/13653</guid><dc:creator><![CDATA[nebulon]]></dc:creator><pubDate>Fri, 25 Sep 2020 09:29:08 GMT</pubDate></item><item><title><![CDATA[Reply to PTR settings incorrect after switching VPS provider on Fri, 25 Sep 2020 09:23:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/christiaan" aria-label="Profile: christiaan">@<bdi>christiaan</bdi></a> you see a grey circle with a question mark click it and the information is there.</p>
]]></description><link>https://forum.cloudron.io/post/13652</link><guid isPermaLink="true">https://forum.cloudron.io/post/13652</guid><dc:creator><![CDATA[imc67]]></dc:creator><pubDate>Fri, 25 Sep 2020 09:23:29 GMT</pubDate></item><item><title><![CDATA[Reply to PTR settings incorrect after switching VPS provider on Fri, 25 Sep 2020 09:06:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/christiaan" aria-label="Profile: christiaan">@<bdi>christiaan</bdi></a> The PTR record is also called the "reverse-DNS". It is set by your hosting provider. Most of them have an option in their admin interface to set it manually to whatever you want. Some don't. You should go look into the admin interface there !</p>
]]></description><link>https://forum.cloudron.io/post/13650</link><guid isPermaLink="true">https://forum.cloudron.io/post/13650</guid><dc:creator><![CDATA[mehdi]]></dc:creator><pubDate>Fri, 25 Sep 2020 09:06:06 GMT</pubDate></item></channel></rss>
