<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Kutt admin account does not show admin actions section]]></title><description><![CDATA[<p dir="auto">I followed the instruction, edit the env file with email address input for admin account. After logged in with admin email, no admin section shows. Tried re-install/restart the apps multiple times.</p>
<p dir="auto">Can someone please help me? I have annually subscription with Cloudron, but sent email to <a href="mailto:support@cloudron.io" target="_blank" rel="noopener noreferrer nofollow ugc">support@cloudron.io</a> two times, waiting for days, no response.</p>
]]></description><link>https://forum.cloudron.io/topic/4728/kutt-admin-account-does-not-show-admin-actions-section</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 16:13:46 GMT</lastBuildDate><atom:link href="https://forum.cloudron.io/topic/4728.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Mar 2021 01:46:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Tue, 26 Oct 2021 20:54:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jdaviescoates" aria-label="Profile: jdaviescoates">@<bdi>jdaviescoates</bdi></a> Thank you</p>
]]></description><link>https://forum.cloudron.io/post/38436</link><guid isPermaLink="true">https://forum.cloudron.io/post/38436</guid><dc:creator><![CDATA[samsls]]></dc:creator><pubDate>Tue, 26 Oct 2021 20:54:57 GMT</pubDate></item><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Tue, 26 Oct 2021 18:15:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/samsls" aria-label="Profile: samsls">@<bdi>samsls</bdi></a> as it mentions in the <a href="https://docs.cloudron.io/apps/kutt/#admin" target="_blank" rel="noopener noreferrer nofollow ugc">docs</a>:</p>
<blockquote>
<p dir="auto">Note that there is <a href="https://github.com/thedevs-network/kutt/issues/385#issuecomment-704322774" target="_blank" rel="noopener noreferrer nofollow ugc">no separate admin section</a>. When a user is admin, they can view all the links in the table in the front page. Look for the 'All links' checkbox.</p>
</blockquote>
]]></description><link>https://forum.cloudron.io/post/38425</link><guid isPermaLink="true">https://forum.cloudron.io/post/38425</guid><dc:creator><![CDATA[jdaviescoates]]></dc:creator><pubDate>Tue, 26 Oct 2021 18:15:24 GMT</pubDate></item><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Tue, 26 Oct 2021 16:26:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi there!<br />
I met the same experience.</p>
<ul>
<li>I modified env file<br />
-check and recheck</li>
<li>restart app<br />
-log out and log in again<br />
Without succes...<br />
Do you remember what did you do to solve this problem?<br />
Thanks in advance</li>
</ul>
]]></description><link>https://forum.cloudron.io/post/38416</link><guid isPermaLink="true">https://forum.cloudron.io/post/38416</guid><dc:creator><![CDATA[samsls]]></dc:creator><pubDate>Tue, 26 Oct 2021 16:26:58 GMT</pubDate></item><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Thu, 25 Mar 2021 02:38:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/girish" aria-label="Profile: girish">@<bdi>girish</bdi></a> Thank You for your support.</p>
]]></description><link>https://forum.cloudron.io/post/28529</link><guid isPermaLink="true">https://forum.cloudron.io/post/28529</guid><dc:creator><![CDATA[A7Cloud]]></dc:creator><pubDate>Thu, 25 Mar 2021 02:38:05 GMT</pubDate></item><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Tue, 23 Mar 2021 01:49:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/a7cloud" aria-label="Profile: a7cloud">@<bdi>a7cloud</bdi></a> said in <a href="/post/28344">Kutt admin account does not show admin actions section</a>:</p>
<blockquote>
<p dir="auto">The only thing I did not do is reinstall cloudron again, which I can't because there are some production apps in place.</p>
</blockquote>
<p dir="auto">Reinstalling Cloudron won't help. I think the issue is something else.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/a7cloud" aria-label="Profile: a7cloud">@<bdi>a7cloud</bdi></a> said in <a href="/post/28322">Kutt admin account does not show admin actions section</a>:</p>
<blockquote>
<p dir="auto">Completely there is no advance features. Ah, there is no show all links check box like your link.</p>
</blockquote>
<p dir="auto">For the checkbox, can you send go to Support -&gt; Enable Remote Access and drop us an email? I can look into why you are not able to see the check box.</p>
<p dir="auto">As for the advanced features like managing users etc, I have never seen these. Can you tell me where you have seen this? Any screenshots or some wiki link? AFACT, this admin page that you are thinking of doesn't exist.</p>
<ul>
<li><a href="https://github.com/thedevs-network/kutt/issues/157" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/thedevs-network/kutt/issues/157</a> is still open</li>
<li><a href="https://github.com/thedevs-network/kutt/issues/144#issuecomment-671333511" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/thedevs-network/kutt/issues/144#issuecomment-671333511</a> says there is no admin form</li>
</ul>
]]></description><link>https://forum.cloudron.io/post/28405</link><guid isPermaLink="true">https://forum.cloudron.io/post/28405</guid><dc:creator><![CDATA[girish]]></dc:creator><pubDate>Tue, 23 Mar 2021 01:49:50 GMT</pubDate></item><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Mon, 22 Mar 2021 19:08:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/a7cloud" aria-label="Profile: a7cloud">@<bdi>a7cloud</bdi></a> To be clear: The screenshots of your settings page are the advanced admin settings <img src="https://forum.cloudron.io/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=b6971addb6c" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:1.4em;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://forum.cloudron.io/post/28375</link><guid isPermaLink="true">https://forum.cloudron.io/post/28375</guid><dc:creator><![CDATA[luckow]]></dc:creator><pubDate>Mon, 22 Mar 2021 19:08:34 GMT</pubDate></item><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Mon, 22 Mar 2021 13:21:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/girish" aria-label="Profile: girish">@<bdi>girish</bdi></a> Yes. As I wrote in my email to support. I tried many times, many ways:<br />
1/ Restarted the app multiple times<br />
2/ Stopped the app, then started<br />
3/ Uninstalled the app then reinstalled</p>
]]></description><link>https://forum.cloudron.io/post/28344</link><guid isPermaLink="true">https://forum.cloudron.io/post/28344</guid><dc:creator><![CDATA[A7Cloud]]></dc:creator><pubDate>Mon, 22 Mar 2021 13:21:33 GMT</pubDate></item><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Mon, 22 Mar 2021 03:33:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/a7cloud" aria-label="Profile: a7cloud">@<bdi>a7cloud</bdi></a> Just to double check - did you restart the app? Also, maybe you can try to logout and login? Thanks.</p>
]]></description><link>https://forum.cloudron.io/post/28326</link><guid isPermaLink="true">https://forum.cloudron.io/post/28326</guid><dc:creator><![CDATA[girish]]></dc:creator><pubDate>Mon, 22 Mar 2021 03:33:10 GMT</pubDate></item><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Mon, 22 Mar 2021 00:53:59 GMT]]></title><description><![CDATA[<p dir="auto">Here is the admin actions on setting page I talked about</p>
<p dir="auto"><img src="/assets/uploads/files/1616374435094-aaef6417-be6b-4c33-ac6e-d7b9bc2c61a8-image.png" alt="aaef6417-be6b-4c33-ac6e-d7b9bc2c61a8-image.png" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.cloudron.io/post/28324</link><guid isPermaLink="true">https://forum.cloudron.io/post/28324</guid><dc:creator><![CDATA[A7Cloud]]></dc:creator><pubDate>Mon, 22 Mar 2021 00:53:59 GMT</pubDate></item><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Mon, 22 Mar 2021 00:06:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/girish" aria-label="Profile: girish">@<bdi>girish</bdi></a><br />
Thanks for your support. I got email from you. The Kutt admin account after login, will have more options to setup on the site, for example: you can decide people need to register an account with Kutt before they can shorten their URL or not. That feature is just an example what an admin can select after logged in with admin email account. Now all are disappear. I can't find those functions anymore. A regular account or an admin account after login show the dashboard the same.<br />
Here is the home page after logged in<br />
<img src="/assets/uploads/files/1616371405860-807c9ede-aab4-41e6-82af-8a7f3ca4e5b6-image-resized.png" alt="807c9ede-aab4-41e6-82af-8a7f3ca4e5b6-image.png" class="img-markdown  img-fluid" /></p>
<p dir="auto">And here is the setting page:<br />
<img src="/assets/uploads/files/1616371495326-72457268-e7f7-4f87-ae93-52dccb7128cb-image.png" alt="72457268-e7f7-4f87-ae93-52dccb7128cb-image.png" class="img-markdown  img-fluid" /></p>
<p dir="auto"><img src="/assets/uploads/files/1616371510344-23c0bf10-d69f-41a1-9af6-ad18cf1243d5-image.png" alt="23c0bf10-d69f-41a1-9af6-ad18cf1243d5-image.png" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.cloudron.io/post/28322</link><guid isPermaLink="true">https://forum.cloudron.io/post/28322</guid><dc:creator><![CDATA[A7Cloud]]></dc:creator><pubDate>Mon, 22 Mar 2021 00:06:52 GMT</pubDate></item><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Sat, 20 Mar 2021 17:37:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/a7cloud" aria-label="Profile: A7Cloud">@<bdi>A7Cloud</bdi></a> I can atleast see that outlook is accepting the emails from us. It would be quite strange if you sent us the email and it rejected our response as spam... IMO, there is no bigger indicator that a message is not spam if the originator sent the mail!</p>
<pre><code>Mar 20 10:33:25 [INFO] [576F3B0C-EF68-4700-A6FC-FA5F13831214.1.1] [outbound] Attempting to deliver to: 104.47.56.110:25 (0) (4)
Mar 20 10:33:25 [INFO] [-] [core] [outbound] [outbound::25:104.47.56.110:undefined:50] dispense() clients=1 available=0
Mar 20 10:33:25 [INFO] [-] [core] [outbound] acquired socket 6AEBE727-16CB-4343-B160-5972DB20F342 for outbound::25:104.47.56.110:undefined:50
Mar 20 10:33:25 [INFO] [576F3B0C-EF68-4700-A6FC-FA5F13831214.1.1] [outbound] secured verified=true cipher=ECDHE-RSA-AES256-GCM-SHA384 version=TLSv1.2 cn=mail.protection.outlook.com organization="Microsoft Corporation" issuer="DigiCert Inc" expires="Feb 5 23:59:59 2022 GMT" fingerprint=5D:44:0E:75:FE:29:C4:D5:A2:23:31:4B:B0:EC:1D:CB:EB:1A:09:03
Mar 20 10:33:26 [NOTICE] [576F3B0C-EF68-4700-A6FC-FA5F13831214.1.1] [outbound] delivered file=1616261604867_1616261604867_0_159_YkPDxz_6371_598f8eb7b100 domain=xxx.com host=xxxx-com.mail.protection.outlook.com ip=104.47.56.110 port=25 mode=SMTP tls=Y auth=N response="&lt;fdaf1d92-b721-3da2-5030-8ba23f0a6433@cloudron.io&gt; [InternalId=24000277252643, Hostname=BN6PR15MB1874.namprd15.prod.outlook.com] 10106 bytes in 0.169, 58.199 KB/sec Queued mail for delivery" delay=2.023 fails=0 rcpts=1/0/0
</code></pre>
]]></description><link>https://forum.cloudron.io/post/28288</link><guid isPermaLink="true">https://forum.cloudron.io/post/28288</guid><dc:creator><![CDATA[girish]]></dc:creator><pubDate>Sat, 20 Mar 2021 17:37:07 GMT</pubDate></item><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Sat, 20 Mar 2021 16:05:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/a7cloud" aria-label="Profile: a7cloud">@<bdi>a7cloud</bdi></a> <a href="https://docs.cloudron.io/apps/kutt/#admin" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.cloudron.io/apps/kutt/#admin</a> (on a side note, I too sent you a mail separate from <a class="plugin-mentions-user plugin-mentions-a" href="/user/nebulon" aria-label="Profile: nebulon">@<bdi>nebulon</bdi></a> with this link)</p>
]]></description><link>https://forum.cloudron.io/post/28286</link><guid isPermaLink="true">https://forum.cloudron.io/post/28286</guid><dc:creator><![CDATA[girish]]></dc:creator><pubDate>Sat, 20 Mar 2021 16:05:51 GMT</pubDate></item><item><title><![CDATA[Reply to Kutt admin account does not show admin actions section on Sat, 20 Mar 2021 12:38:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">strange I have responded from support@ to your support request, maybe it ended up in your spam folder?<br />
Anyways I tested this as well using the env file and the env file as such is working for the app, however I was also not able to find any such "admin" ui anywhere. I don't think there is one or if so, can you point me to where to find that?</p>
]]></description><link>https://forum.cloudron.io/post/28282</link><guid isPermaLink="true">https://forum.cloudron.io/post/28282</guid><dc:creator><![CDATA[nebulon]]></dc:creator><pubDate>Sat, 20 Mar 2021 12:38:17 GMT</pubDate></item></channel></rss>
