<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Something broke remote checks.. local OK]]></title><description><![CDATA[<p dir="auto">This is odd, the recent update seems to have broken update checks and TG notifications for a few sites yet not others.</p>
<p dir="auto">I run HTTPS checks with a keyword and for some reason the app from the container cannot connect to the IP of a select few domains any more.</p>
<p dir="auto">ping from the terminal of the app, gets no data back, just blank.</p>
<p dir="auto">ping from the host via ssh, works just fine.</p>
<p dir="auto">So now the dashboard is screaming bloody murder in lots of red, when 2 domains are actually up.</p>
<p dir="auto">The logs show warnings for the hosts it's timing out on as well as other odd errors:</p>
<pre><code>Jan 12 21:46:34 2023-01-12T21:46:34-08:00 [MONITOR] ERROR: Cannot send notification to TG Alert - Uptime-bot
Jan 12 21:46:34 TypeError: Cannot read properties of undefined (reading 'data')
Jan 12 21:46:34 at Telegram.send (/app/code/server/notification-providers/telegram.js:21:39)
Jan 12 21:46:34 at processTicksAndRejections (node:internal/process/task_queues:96:5)
Jan 12 21:46:34 at async Function.sendNotification (/app/code/server/model/monitor.js:1098:21)
Jan 12 21:46:34 at async beat (/app/code/server/model/monitor.js:660:21)
Jan 12 21:46:34 at async Timeout.safeBeat [as _onTimeout] (/app/code/server/model/monitor.js:728:17)
</code></pre>
<p dir="auto">All remote monitors seem to be broken, while all local host/domain monitors are working.</p>
<p dir="auto">I set up a monitor for <a href="http://google.com" target="_blank" rel="noopener noreferrer nofollow ugc">google.com</a> and it's down too <img src="https://forum.cloudron.io/assets/plugins/nodebb-plugin-emoji/emoji/android/1f606.png?v=090c346130c" class="not-responsive emoji emoji-android emoji--laughing" style="height:23px;width:auto;vertical-align:middle" title=":laughing:" alt="😆" /></p>
<p dir="auto">Update: demo cloudron kuma instance doesn't appear to have the same issues.</p>
<p dir="auto">Update2: cloning a pervious version from backup doesn't help.<br />
Also, new install on separate subdomain doesn't make it work any better.</p>
]]></description><link>https://forum.cloudron.io/topic/8438/something-broke-remote-checks-local-ok</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 04:50:26 GMT</lastBuildDate><atom:link href="https://forum.cloudron.io/topic/8438.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Jan 2023 05:57:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Thu, 19 Jan 2023 11:21:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/girish" aria-label="Profile: girish">@<bdi>girish</bdi></a> done <a href="https://forum.cloudron.io/topic/8487/enhance-app-proxy-app-with-path-and-port-support">https://forum.cloudron.io/topic/8487/enhance-app-proxy-app-with-path-and-port-support</a></p>
]]></description><link>https://forum.cloudron.io/post/60472</link><guid isPermaLink="true">https://forum.cloudron.io/post/60472</guid><dc:creator><![CDATA[robi]]></dc:creator><pubDate>Thu, 19 Jan 2023 11:21:18 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Mon, 16 Jan 2023 09:26:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robi" aria-label="Profile: robi">@<bdi>robi</bdi></a> ah, indeed. Maybe you installed something a long time ago! It's running for 2 years lol</p>
]]></description><link>https://forum.cloudron.io/post/60171</link><guid isPermaLink="true">https://forum.cloudron.io/post/60171</guid><dc:creator><![CDATA[girish]]></dc:creator><pubDate>Mon, 16 Jan 2023 09:26:59 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Sun, 15 Jan 2023 21:12:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/girish" aria-label="Profile: girish">@<bdi>girish</bdi></a> Did not think to look at iptables, ugh.</p>
<p dir="auto">Yes, stuff works at least! Thank you.</p>
<p dir="auto">There were some package upgrades. But don't remember which.</p>
<p dir="auto">Ooh, watchtower from 2 years ago? Looks like I forgot about playing with that. Nope, no effect, but it would be nice to see those in the Cloudron UI.</p>
<p dir="auto">Happy Sunday</p>
]]></description><link>https://forum.cloudron.io/post/60150</link><guid isPermaLink="true">https://forum.cloudron.io/post/60150</guid><dc:creator><![CDATA[robi]]></dc:creator><pubDate>Sun, 15 Jan 2023 21:12:34 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Sun, 15 Jan 2023 16:41:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robi" aria-label="Profile: robi">@<bdi>robi</bdi></a> I rebooted the server and it fixed up the iptable issue atleast. mail container seems to be back now and I am also able wget/curl etc from the uptime kuma container.</p>
<p dir="auto">I am not sure what messed up with you iptables though. Did you upgrade recently? I do see that there are some non-cloudron docker container in the server (like watchtower), not sure what effect they have.</p>
]]></description><link>https://forum.cloudron.io/post/60141</link><guid isPermaLink="true">https://forum.cloudron.io/post/60141</guid><dc:creator><![CDATA[girish]]></dc:creator><pubDate>Sun, 15 Jan 2023 16:41:06 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Sun, 15 Jan 2023 10:34:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robi" aria-label="Profile: robi">@<bdi>robi</bdi></a> said in <a href="/post/60117">Something broke remote checks.. local OK</a>:</p>
<blockquote>
<p dir="auto">The plot thickens.</p>
</blockquote>
<p dir="auto">SSDNodes having a wobble?</p>
]]></description><link>https://forum.cloudron.io/post/60119</link><guid isPermaLink="true">https://forum.cloudron.io/post/60119</guid><dc:creator><![CDATA[jdaviescoates]]></dc:creator><pubDate>Sun, 15 Jan 2023 10:34:04 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Sun, 15 Jan 2023 08:39:40 GMT]]></title><description><![CDATA[<p dir="auto">Email is no longer accessible, all clients cannot connect.</p>
<p dir="auto">Checking services, email service is green, but logs are empty.. restarting the mail service fails with a long red error.</p>
<pre><code>Cloudron Error
Command failed: docker run --restart=always -d --name="mail" --net cloudron --net-alias mail --log-driver syslog --log-opt syslog-address=udp://127.0.0.1:2514 --log-opt syslog-format=rfc5424 --log-opt tag=mail -m 429916160 --memory-swap 536870912 --dns 172.18.0.1 --dns-search=. -e CLOUDRON_MAIL_TOKEN="xxxxxx" -e CLOUDRON_RELAY_TOKEN="xxxxxx" -e LOGLEVEL=info -v "/home/yellowtent/boxdata/mail:/app/data" -v "/home/yellowtent/platformdata/addons/mail:/etc/mail:ro" -p 587:2587 -p 993:9993 -p 4190:4190 -p 25:2587 -p 465:2465 -p 995:9995 --label isCloudronManaged=true --read-only -v /run -v /tmp cloudron/mail:3.7.4@sha256:8ddbf13ee3fd479e18923c7bf1370d9d8aa5f12a94cbbda5afac8b5a4af72a28 docker: Error response from daemon: driver failed programming external connectivity on endpoint mail (ddb03fa18c2bf483ec4782d27b2e31a9f774bd5e835b1a15c830d2d38ee82b50): (iptables failed: ip6tables --wait -t filter -A DOCKER ! -i br-e5579f54c902 -o br-e5579f54c902 -p tcp -d fd00:c107:d509::17 --dport 4190 -j ACCEPT: ip6tables: No chain/target/match by that name. (exit status 1)).
</code></pre>
<p dir="auto">I thought to restart docker, but if it fails to restart, all sites will be down ;-/</p>
]]></description><link>https://forum.cloudron.io/post/60117</link><guid isPermaLink="true">https://forum.cloudron.io/post/60117</guid><dc:creator><![CDATA[robi]]></dc:creator><pubDate>Sun, 15 Jan 2023 08:39:40 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Sun, 15 Jan 2023 08:06:16 GMT]]></title><description><![CDATA[<p dir="auto">Things are getting worse as other container apps are now failing, not able to reach their DB, or failing upgrades (DB migration), etc.</p>
<p dir="auto">Not sure what's going on, but container networking has something to do with it.</p>
]]></description><link>https://forum.cloudron.io/post/60116</link><guid isPermaLink="true">https://forum.cloudron.io/post/60116</guid><dc:creator><![CDATA[robi]]></dc:creator><pubDate>Sun, 15 Jan 2023 08:06:16 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Fri, 13 Jan 2023 15:09:26 GMT]]></title><description><![CDATA[<p dir="auto">Things I checked:</p>
<p dir="auto"></p><div class="plugin-markdown"><input type="checkbox" />Network configuration: The Docker container may not be configured to use the host's network, which would prevent it from accessing public IPs.</div><p></p>
<p dir="auto"></p><div class="plugin-markdown"><input type="checkbox" />Firewall rules: A firewall on the host machine may be blocking incoming connections from the Docker container.</div><p></p>
<p dir="auto"></p><div class="plugin-markdown"><input type="checkbox" checked="true" />DNS resolution: The Docker container may not be able to resolve public DNS names to IP addresses.</div><p></p>
<p dir="auto"></p><div class="plugin-markdown"><input type="checkbox" checked="true" />Network address translation (NAT): The host machine may be configured to use NAT, which would prevent the Docker container from accessing public IPs.</div><p></p>
<p dir="auto"></p><div class="plugin-markdown"><input type="checkbox" checked="true" />Inadequate permissions: The user running the container may not have the necessary permissions to access the host's network.</div><p></p>
<p dir="auto"></p><div class="plugin-markdown"><input type="checkbox" />Network isolation: The network namespace of the container can be isolated from the host machine thus it has only access to the local IPs.</div><p></p>
]]></description><link>https://forum.cloudron.io/post/60023</link><guid isPermaLink="true">https://forum.cloudron.io/post/60023</guid><dc:creator><![CDATA[robi]]></dc:creator><pubDate>Fri, 13 Jan 2023 15:09:26 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Fri, 13 Jan 2023 14:32:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/girish" aria-label="Profile: girish">@<bdi>girish</bdi></a> that's the wrong conclusion.</p>
<p dir="auto">original app with TG notifications has the crash</p>
<p dir="auto">new test app w/o TG notifications has only the monitors failing</p>
<p dir="auto">The CL UI also seems slower than usual.<br />
send you an email with logs</p>
]]></description><link>https://forum.cloudron.io/post/60016</link><guid isPermaLink="true">https://forum.cloudron.io/post/60016</guid><dc:creator><![CDATA[robi]]></dc:creator><pubDate>Fri, 13 Jan 2023 14:32:14 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Fri, 13 Jan 2023 14:28:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robi" aria-label="Profile: robi">@<bdi>robi</bdi></a> strange.. might want to report this upstream then. Not sure why something with no notifications is erroring in telegram code.</p>
]]></description><link>https://forum.cloudron.io/post/60014</link><guid isPermaLink="true">https://forum.cloudron.io/post/60014</guid><dc:creator><![CDATA[girish]]></dc:creator><pubDate>Fri, 13 Jan 2023 14:28:02 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Fri, 13 Jan 2023 14:38:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/girish" aria-label="Profile: girish">@<bdi>girish</bdi></a> no, because a new instance which doesn't have notifications setup has the same issue.</p>
<p dir="auto">the crashing seems to be from being unable to reach Telegram.</p>
<p dir="auto">so this is something with outbound container networking..</p>
]]></description><link>https://forum.cloudron.io/post/60013</link><guid isPermaLink="true">https://forum.cloudron.io/post/60013</guid><dc:creator><![CDATA[robi]]></dc:creator><pubDate>Fri, 13 Jan 2023 14:38:06 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Fri, 13 Jan 2023 10:54:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robi" aria-label="Profile: robi">@<bdi>robi</bdi></a> Does disabling telegram notification make things any better ? (the stack trace you posted is the telegram notification crashing)</p>
]]></description><link>https://forum.cloudron.io/post/59992</link><guid isPermaLink="true">https://forum.cloudron.io/post/59992</guid><dc:creator><![CDATA[girish]]></dc:creator><pubDate>Fri, 13 Jan 2023 10:54:58 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Fri, 13 Jan 2023 10:38:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/girish" aria-label="Profile: girish">@<bdi>girish</bdi></a> the DB size is at 62MB keeping data for 180 days. Doesn't look like that's the issue as it works for private IPs but not public IPs.</p>
<p dir="auto">On a new instance, I even added 1.1.1.1, and it also fails by timing out. So it's not DNS related.</p>
<p dir="auto">Something about docker/container but not host. (base image?)<br />
So odd.</p>
]]></description><link>https://forum.cloudron.io/post/59989</link><guid isPermaLink="true">https://forum.cloudron.io/post/59989</guid><dc:creator><![CDATA[robi]]></dc:creator><pubDate>Fri, 13 Jan 2023 10:38:00 GMT</pubDate></item><item><title><![CDATA[Reply to Something broke remote checks.. local OK on Fri, 13 Jan 2023 09:23:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robi" aria-label="Profile: robi">@<bdi>robi</bdi></a> said in <a href="/post/59974">Upgrade broke remote checks?</a>:</p>
<blockquote>
<p dir="auto">Jan 12 21:46:34 TypeError: Cannot read properties of undefined (reading 'data')</p>
</blockquote>
<p dir="auto">Maybe upstream missed some db migration. We use the telegram updates as well but our instance is doing OK. An idea could be to delete the telegram notification and/or the websites throwing an error and add them again.</p>
]]></description><link>https://forum.cloudron.io/post/59980</link><guid isPermaLink="true">https://forum.cloudron.io/post/59980</guid><dc:creator><![CDATA[girish]]></dc:creator><pubDate>Fri, 13 Jan 2023 09:23:44 GMT</pubDate></item></channel></rss>
