  2. Nextcloud
  3. OIDC for Nextcloud?
OIDC for Nextcloud?
26 Posts 6 Posters 10.0k Views 6 Watching
  • J
    @andreasdueren can you also check if you can curl the openid-configuration from web terminal of nextcloud? do you see any errors in nextcloud logs? everything looks correct otherwise...
    andreasduerenA jdaviescoatesJ 2 Replies Last reply
      andreasduerenA
      andreasduerenA
      andreasdueren
      @Joseph You mean curl https://my.domain.com/.well-known/openid-configuration? Yes that's what I tested. Returned values as expected.
        @andreasdueren you may have already done this but I think the key bit of info was this:
        @joseph said in OIDC for Nextcloud?:
        (emphasis added)
          (emphasis added)
          andreasduerenA
          andreasduerenA
          andreasdueren
          @jdaviescoates Yes, I did that (emphasis added) ☺
          • J
            @andreasdueren I am out of ideas if there is nothing in the logs and the curl works... can you drop a mail to support@cloudron.io please, so we can debug it?
              andreasduerenA
              andreasduerenA
              andreasdueren
              @Joseph It's not super urgent right now, this is only a test instance I spun up and I'm traveling right now. I might reach out at a later point in time.
