  2. OpenHAB
  3. OpenHAB not starting after installation
Scheduled Pinned Locked Moved Solved OpenHAB
5 Posts 2 Posters 2.1k Views 2 Watching
  • R Offline
    R Offline
    Robin
    I've installed it, but in the dashboard, it stays in state "Starting..." and the web UI never comes up. Running Cloudron v7.3.4 on 20.04.1 LTS.
    Logs says this (in a loop), unfortunately, without more details:
    Dec 12 22:20:28 ==> Ensure directories
    Dec 12 22:20:28 ==> Changing ownership
    Dec 12 22:20:28 ==> Starting OpenHAB
    Dec 12 22:20:34 ==> Ensure directories
    Dec 12 22:20:34 ==> Changing ownership
    Dec 12 22:20:35 ==> Starting OpenHAB
    Dec 12 22:20:42 ==> Ensure directories
    Dec 12 22:20:42 ==> Changing ownership
    Dec 12 22:20:42 ==> Starting OpenHAB
    Dec 12 22:20:51 ==> Ensure directories
    Dec 12 22:20:51 ==> Changing ownership
    Dec 12 22:20:51 ==> Starting OpenHAB
    • nebulonN Away
      nebulonN Away
      can you maybe put the app in recovery mode and open a webterminal into the app.
      The command which seems to fail from the /app/pkg/start.sh would be gosu cloudron:cloudron /app/code/runtime/bin/karaf daemon maybe run this manually, with debug options (although I don't know from the top of my head what flags this command has for this)
      • R Offline
        R Offline
        Robin
        @nebulon said in OpenHAB not starting after installation:
        Weird.. When I ran /app/pkg/start.sh in recovery mode, I got this:
        Killed
        When I started the last command by hand, it actually seemed to run okay (at least, no output, and it didn't get killed...
        I had a hunch that maybe it was getting OOM killed, and sure enough, I raised the memory allocation to 512m, and it now seems to start successfully, so maybe the default allocation (256m I think it was?) is just a little too low to start, sometimes?
        • R Robin
          Killed
          nebulonN Away
          nebulonN Away
          @Robin alright, I will increase the default memory limit then for the next release.
            nebulonN Away
            nebulonN Away
            I see I already upped the memory limit some time ago, just pending a new package release.
