  2. Collabora Online (CODE)
  3. Allow List for WOPI requests
Scheduled Pinned Locked Moved Solved Collabora Online (CODE)
26 Posts 8 Posters 28.5k Views 8 Watching
    This setting is locking down the nextcloud host to only accept WOPI requests from collabora on that subnet, which is the local docker network on Cloudron. I have tried this here and setting 172.18.0.0/16 works as expected. Do you have any more information about the issue?
      @SebGG maybe your system is connecting via ipv6 only there so can you try to use fd00:c107:d509::/64 instead of the ipv4 one?
      • S
        S
        SebGG
        Hi, no, the ipv6 adress also doesnt work. Is there a way to check this in a deeper way?
          Do you see any errors to work with?
          For explanation, the collabora app backend will contact the Nextcloud instance. So Nextcloud can then only allow incoming requests on those routes by limiting to local connections with setting this netmask.
          • S
            S
            SebGG
            I digged a bit deeper in and here are the logs for two requests for the same document. The first one is with the WOPI adress as documented and the second one it with my external real ipv4 adress. Withe the external real ipv4 adress it works and i can open the documents. i found that here "https://github.com/nextcloud/richdocuments/issues/2685"
            With Wopi Adress 172.18.0.0/16:
            "GET /index.php/apps/richdocuments/wopi/files/542576_oc2a6lhu6gbc?access_token=vmAdhoDd9DnOnITRqNn235KjCmxEUwjp&access_token_ttl=0 HTTP/1.1" 403 2 "-" "COOLWSD HTTP Agent 24.04.7.1"
            "GET /index.php/apps/richdocuments/wopi/files/542576_oc2a6lhu6gbc?access_token=vmAdhoDd9DnOnITRqNn235KjCmxEUwjp&access_token_ttl=0&permission=edit HTTP/1.1" 403 2 "-" "COOLWSD HTTP Agent 24.04.7.1"
            With Wopi Adress real IPv4 Adress :
            "GET /index.php/apps/richdocuments/wopi/files/542576_oc2a6lhu6gbc?access_token=YGfINlPRSbkt7OLGw3VHMxuFSE19cX1v&access_token_ttl=0 HTTP/1.1" 200 853 "-" "COOLWSD HTTP Agent 24.04.7.1"
            "GET /index.php/apps/richdocuments/wopi/files/542576_oc2a6lhu6gbc/contents?access_token=YGfINlPRSbkt7OLGw3VHMxuFSE19cX1v&access_token_ttl=0 HTTP/1.1" 200 6345 "-" "COOLWSD HTTP Agent 24.04.7.1"
              I am no WOPI expert and also cannot reproduce this still. A 403 status code would to me more look like the accesstoken (which is different in both requests you pasted) is invalid. But could be that Nextcloud does return a 403 also for blocked IPs. You have to ask the upstream developers for such details.
              One idea, can you double check which IP range your local cloudron docker network uses? You can do this via SSH docker network inspect cloudron
