  2. Loomio
  3. Loomio Import
Loomio Import
Scheduled Pinned Locked Moved Solved Loomio
11 Posts 4 Posters 5.4k Views 4 Watching
  • D
    D
    darren
    I'm trying to import Loomio data to a new Cloudron instance and I can't for the life of me figure out how to access the running Rails console as suggested in Loomio's documentation:
    Access the running Rails console:
    docker exec -ti loomio-app rails console
    Call the service:
    GroupExportService.import('/import/your-group-data.json')
    Running the following in the terminal:
    rails console
    Produces:
    /usr/local/lib/ruby/gems/3.2.0/gems/activerecord-7.0.7.2/lib/active_record/connection_adapters/abstract/connection_handler.rb:261:in `resolve_pool_config': database configuration does not specify adapter (ActiveRecord::AdapterNotSpecified)
    Does anyone have a method for being able to import a Loomio export?
    • D darren
      Call the service:
      rails console
      Produces:
      @darren On Cloudron, the containers are organized differently. You have to
      • First, upload the export file using the File manager . Say to /tmp or something
      • Then, use Web terminal to run rails commands.
        I put some docs here - https://docs.cloudron.io/apps/loomio/#rails-console
        • D
          D
          darren
          Thanks @girish! This is helpful. Apologize if I'm missing something... I'm still encountering an error when I try to start the rail console in the web terminal following setting those environment variables:
          `validate_secret_key_base': Missing `secret_key_base` for 'production' environment, set this string with `bin/rails credentials:edit`
          Do I need to set something else?
          • D darren
            @darren You are right, I forgot a step . Please run source /app/data/env.sh before you start the rails console. I am fixing the docs.
            • D
              D
              darren
              Perfect! Thanks again @girish I'm in now
              • jdaviescoatesJ
                @darren is this you importing data from the hosted Loomio to a self-hosted Loomio on Cloudron? If so, cool! I may do that too...
                D 1 Reply Last reply
                  D
                  D
                  darren
                  @jdaviescoates yes that's the case. I was able to import a large group from hosted Loomio into self-hosted Loomio on Cloudron. The import seems stable so far.
                  • D
                    D
                    darren
                    @girish I just realized that the hourly cron loomio-deploy recommends [and that's already in the cloudron package] was failing. I think similarly because the db connection wasn't defined for
                    bundle exec rake loomio:hourly_tasks
                    How should I proceed? I can schedule my own cron but it seems like this might be something that should be updated in the base cloudron package for loomio?
                      I can confirm the issue. Preparing a new app package now.
                        Latest package release has this fixed now.
