  2. Change Detection
  3. module 'lxml.etree' has no attribute '_ElementStringResult'
Scheduled Pinned Locked Moved Change Detection
11 Posts 3 Posters 5.6k Views 3 Watching
  • P Offline
    P Offline
    p44
    After last update to 0.45.17, I've this problem:
    "module 'lxml.etree' has no attribute '_ElementStringResult'"
    Any other have this issue?
    Thank's a lot
    • girishG Do not disturb
      Does this happen on all sites? How can we reproduce? Our app is running fine.
      • P Offline
        P Offline
        p44
        wrote on last edited by p44
        @girish it happens randomly...
        Edit: problem it seems to be related tho scrapes that have configured "CSS/JSONPath/JQ/XPath Filters" instruction populated from "Visual Filter Selector".
        So, to reproduce please try to do this:
        • Add a website Url
        • In Request Select "Playwright Chromium/Javascript via 'ws://0.0.0.0:3000'"
        • In "Visual Filter Selector" select some area
        • Save
        At this point, you should have "CSS/JSONPath/JQ/XPath Filters" populated with filters, eg. xpath1:/html/body/div[2]
        Let me know,
        Thank's a lot
        • nebulonN Away
          nebulonN Away
          maybe this is worth reportin upstream then so they know and can debug/fix this.
          • P Offline
            P Offline
            p44
            @nebulon first I want to be sure that is not a Cloudron-related problem, than maybe I'll open upstream.
            Maybe is this issue related to Python version?
            • nebulonN Away
              nebulonN Away
              I think it would help to report to upstream as it does not appear to be a generic package issue and so far we are not able to reproduce this. Nor are we experts on the app internals itself, so upstream authors may be able to shed more light on this.
                P Offline
                P Offline
                p44
                @nebulon @girish asked "how we can reproduce"... so you confirm you replicated steps above and issue was not reproduced?
                • nebulonN Away
                  nebulonN Away
                  Yes, I tried it with two different webpages but seems to work fine here.
                  • P Offline
                    P Offline
                    p44
                    @nebulon thank's...
                      @p44 I think https://github.com/dgtlmoon/changedetection.io/issues/2312 is this issue. They have fixed it in the latest release.
                      • P Offline
                        P Offline
                        p44
                        @girish seems to be that they fixed... but I've to test yet. @girish thank's a lot for your patience 🙂
