  2. Keycloak
  3. Enabling features
Enabling features
Scheduled Pinned Locked Moved Keycloak
26 Posts 7 Posters 8.3k Views 7 Watching
  • G
    G
    gpichler
    @shrey You could try my patch in the MR https://git.cloudron.io/packages/keycloak-app/-/merge_requests/12 :
    Add the .jar in the providers/, add additional commandline flags in env.sh and then simply restart the container.
      @gpichler @shrey we will try to get the MR merged soonish . Just have to double check if there is any other workaround we can use because we really dislike code being writable!
      • G
        G
        gpichler
        @girish Out of curiosity: What is your rational for not liking code being writable? Is it a security consideration?
          Security is one but equally important is it for updating apps. If code files are changed we can't test and validate updates and each update will overwrite any local changes anyways.
          • G
            G
            gpichler
            I see. In the case of this MR, the executable (the .jar file) is rebuilt on every app startup. Thus, this would not be overwritten by an update. The relevant commandline parameters are persistent in env.sh when updating.
            I think there are two failure modes after an update: 1) obsolete commandline parameters in env.sh or 2) .jar files in providers/, which were compatible with the previous version but incompatible with the new version. If you want to allow users to select custom features and install custom providers. I think both these options are essentially unavoidable.
            Let me know if there is something I can improve. I am looking forward to getting this merged. 🙂
              @gpichler @msbt I have merged it now and published it
