  3. 535 5.7.8 Authentication failed - SMTP Error
ratelimitsecuritysmtpauthentication
12 Posts 2 Posters 3.8k Views 2 Watching
  • W Offline
    W Offline
    webliska
    Hello,
    I'm facing an issue with SMTP: Authentication failed.
    Basically, I have connected my email to a warmup service. The connections work fine for a few hours, like 4-5 hours, and after that, the warmup service starts showing me a connection error, the same error I mentioned
    So I go ahead and restart the connection again in the tool, and it starts working fine again for a few hours, and then the same Auth failure.
    I have read this online:
    Warmup Inboxes tool makes too many SMTP/IMAP connections or too frequent auth attempts (which is common in warming tools), Cloudron may temporarily block or delay further authentication.
    Am I digging in the right direction? If yes, then please let me know how I can resolve the issue and get this done?
    I also did not see any errors in the log files regarding this.
    Can you please help me with the issue?
    Thanks!
      Hello @webliska
      Cloudron does enforce some rate limits as described in the documentation.
      • Email access (Port 25, 465, 587, 993, 4190) - 50 connections per second per IP/App.
      • Email relay access - 500 connections per second per app.
      • Email receive access - 50 connections per second per app.
      So yes, you might have hit the rate limit.
      You can check all rate limited entries when connect to your server via ssh and root or sudo access with the following command:
      iptables -t filter -L CLOUDRON_RATELIMIT
      You could also view the syslog and filter for IPTables RateLimit or watch the output in real time with:
      tail -f /var/log/syslog | grep -i 'IPTables RateLimit'
      You could try to simply restart the cloudron-firewall.service that would also clear the rate limited table.
      Suggested solution to clear all rate limited ips
      systemctl restart cloudron-firewall.service
      • W Offline
        W Offline
        webliska
        wrote on last edited by webliska
        Thank you!
        I checked the logs but did not find anything here:
        Also, I checked this:
        iptables -t filter -L CLOUDRON_RATELIMIT confirms the rate limits are active.
        So I went ahead and checked the logs with the IPs that the warmup services are using to connect, but did not find any logs of them in the /var/log/syslog
        Also, one more thing, I confirmed with the Warmup service team about the connections limits per second and they toldme this:
        If that´s the case, then it´s even more odd because we are not doing up to 50 connection attempts per second.
        So this also confirms that it's something odd.
        Let me know.
        Thanks!
        Can you please let me know how to get this issue resolved?
        I do not want to clear all rate-limited ips as this might also remove some unwanted users as well.
        Is there a way to whitelist those IPs that I want?
        Please help me with that.
        Thanks!
          @webliska said in 535 5.7.8 Authentication failed - SMTP Error:
          From the documentation. There is a Blacklist => https://docs.cloudron.io/networking/#blocklist
          But also Trusted IPs, but I am unsure if the Trusted IPs feature is also whitelisting from rate limit.
          @staff can we get some insight about Trusted IPs?
          Regarding the failing auth for smtp. I'd need the log / error message of why the auth failed to further analyze the issue.
          But you can always test the credentials yourself with e.g. thunderbird.
          • W Offline
            W Offline
            webliska
            The credentials are all good and double tested multiple times.
            What logs do you want, let me know.
            • W webliska
              @webliska
              If the warmup provider gets SMTP: Authentication failed, a full error message from the client would be useful.
              Also, the log from my.DOMAIN.TLD/#/services mail service logs.
              With a timestamp from the failed auth attempt and the log of the mail service we could find more details about why it is failing.
                I just talked to the @staff about Trusted IPs and I was correct in my assumption.
                Trusted IPs are not excluded from the Rate Limits.
                  Since Cloudron uses Haraka as the mailer.
                  There also further rate limiting factors from Haraka itself.
                  See => https://github.com/haraka/haraka-plugin-limit/blob/master/config/limit.ini
                  Excerpt:
                  # limit number of connections per interval from IP/rDNS
                  [rate_conn]
                  enabled=true
                  127=0
                  172=0
                  default=60/1m
                  ; Maximum number of recipients from an IP or host over an interval
                  [rate_rcpt_host]
                  enabled=true
                  127=0
                  172=0
                  ; 50 RCPT To: maximum in 5 minutes
                  default=100/5m
                  Editing these values out of the box is not possible.
                  So please reevaluate with your warmup provider if these rate limits also met.
                  • W Offline
                    W Offline
                    webliska
                    How do I send you the mail.log?
                    The full error code is the following: 535 5.7.8 Authentication failed
                    This indicates either an invalid SMTP username or password.
                    • W webliska
                      You can put the mail log into https://paste.cloudron.io/ and send the URL here or send me a private message in the forum.
                      • W Offline
                        W Offline
                        webliska
                        @james I have sent the logs in the private message.
                          Hello @webliska
                          After our private chat and the suggestion to add IPv6 is this still an issue, or can I mark this topic as solved?
