  2. OpenWebUI
  3. Problem updating to 3.0.5
8 Posts 2 Posters 1.1k Views 2 Watching
  • S Offline
    S Offline
    ssweber
    After updating to 3.0.5 (or 3.0.6) I get the following response on all chats:
    'NoneType' object has no attribute 'get'
    I looked at the updating log, and the only issue I saw was this:
    Dec 22 16:12:03 ==> Setting permissions
    Dec 22 16:12:03 invalid command \".
    Dec 22 16:12:03 ERROR: invalid input syntax for type json
    Dec 22 16:12:03 LINE 1: UPDATE config SET data= E'{"version":0,"ui":{"default_locale...
    Dec 22 16:12:03 ^
    Dec 22 16:12:03 DETAIL: Token ""Check the following sentence for grammar and clarity: \"[sentence]" is invalid.
    Dec 22 16:12:03 CONTEXT: JSON data, line 1: ...ng sentence for grammar and clarity: \"[sentence]
    Dec 22 16:12:03 ==> Update OIDC config
    Dec 22 16:12:03 ==> Starting OpenWebUI
    Dec 22 16:12:04 /app/code/backend/open_webui/env.py:425: SyntaxWarning: invalid escape sequence '\d'
    Dec 22 16:12:04 "^(?=.*[a-z])(?=.*[A-Z])(?=.*\d)(?=.*[^\w\s]).{8,}$",
    Dec 22 16:12:04 /app/code/backend/open_webui/env.py:433: SyntaxWarning: invalid escape sequence '\d'
    Dec 22 16:12:07 INFO [alembic.runtime.migration] Context impl PostgresqlImpl.
    Dec 22 16:12:07 INFO [alembic.runtime.migration] Will assume transactional DDL.
    Dec 22 16:12:07 INFO [alembic.runtime.migration] Running upgrade 3e0e00844bb0 -> 6283dc0e4d8d, Add channel file table
    Dec 22 16:12:07 INFO [alembic.runtime.migration] Running upgrade 6283dc0e4d8d -> 81cc2ce44d79, Update channel file and knowledge table
    Dec 22 16:12:07 INFO [alembic.runtime.migration] Running upgrade 81cc2ce44d79 -> c440947495f3, Add chat_file table
    Dec 22 16:12:07 WARNI [open_webui.env]
    Dec 22 16:12:07 2025-12-22T21:12:07Z
    Dec 22 16:12:07 WARNING: CORS_ALLOW_ORIGIN IS SET TO '*' - NOT RECOMMENDED FOR PRODUCTION DEPLOYMENTS.
    Dec 22 16:12:10 => Healthcheck error: Error: connect ECONNREFUSED ...:8080
    Dec 22 16:12:13 WARNI [langchain_community.utils.user_agent] USER_AGENT environment variable not set, consider setting it to identify your requests.
    Dec 22 16:12:15 2025-12-22T21:12:15Z
    Anyone else have a problem?
    • S Offline
      S Offline
      ssweber
      Ignore the log error. That looked to be present in 3.0.4 as well.
      • S Offline
        S Offline
        ssweber
        Hmm. Re-upgraded to 3.0.5 and it's working. I'll update to 3.0.6 and see if it's still working
        • S Offline
          S Offline
          ssweber
          Consider this closed. I did get the error again, but then I read I should turn embedding engine on and off.
          I had the “ Bypass Embedding and Retrieval” On. I turned it off. And that seemed to have fixed the problem.
          See https://docs.openwebui.com/troubleshooting/rag/
          Go to: Admin Settings > Documents > Embedding Model
          Save the embedding model again—even if it's already selected. This forces a recheck/download.
            Hello @ssweber
            Thanks for reporting and keeping a detailed log on your solution finding process.
            This helps future readers and is much appreciated.
            • S Offline
              S Offline
              ssweber
              As it turns out, that wasn't really the fix.
              With each new 'page load', the same things happens. But if I reload the same conversation after visiting like the admin page, and resend the chat, then it works.
              Maybe next week I'll have time to debug and create an issue on their github
              • S Offline
                S Offline
                ssweber
                Looks like there have been some fixes related to this going into next version: https://github.com/open-webui/open-webui/issues/20365
                • S Offline
                  S Offline
                  ssweber
                  Newest package that ships Open WebUI 0.7.2 resolved this
