  3. Trilium - hierarchical note taking application with focus on building large personal knowledge bases
25 Posts 11 Posters 15.4k Views 12 Watching
  • ruihildtR ruihildt
    @seeker
    When I started using notes, I wanted to have them as text files in order to have them in a simple format and find the editor that would feel the most natural for my workflow.
    I have used Joplin, Typora, Zettlr, FocusWriter. And I settled on Joplin for some time. I think I moved out because of sync issues and also because the interface was a bit too terse for my liking.
    I then tried Obsidian.md (and its extension) which blew out all of these, but unfortunately is not free software.
    This experience changed my priorities, and I moved to Trilium because as it's not text based, you can use advanced workflow (for example, create everyday a note with the current date, but the best is to check out the demo content from Trilium), have notes appearing in multiple place in a tree structure (which I discovered was important for me) and is super scriptable.
    Check out this mad person turning Trilium notes into a CMS: https://wingysam.xyz/posts/tePIFQKUbTQ3
    I also hoped there would be an android app, but it's not the case. The mobile version is really usable though, so eventually I'd like to help make it a PWA.
    #21
    @ruihildt said in Trilium - hierarchical note taking application with focus on building large personal knowledge bases:
    I guess you could "install" it as a browser app so it has its own button and auto logs in?
    I do this with lots of forums I use regularly.
      @seeker
      S
      S
      seeker
      @ruihildt
      Thank you. Scripting is one of the things I see Trilium praised about. My understanding of scripting is minimal. But I understand enough to see how that could be a game changer. It is a matter of weather I would use the scripting. A few of the existing scripts might be useful enough for me to make the leap. But what about using it when away from my pc. I really need a way to bridge the phone and the pc with as little friction as possible. Being able to take notes while reading a report or reviewing a video or an audio file on my mobile phone would be extremely helpful.
      Obsidian is pretty amazing. It is part of a broader evolution of knowledge management. I know a number of people who are using it and loving it. I have also heard good things about logseq and athens While plain text is future proof, it is difficult when working with video and audio files.
      I discovered Codex I really like the freeform access it give to one's data- specifically multimedia. But I have not had a chance to look deeply into it. I suspect that there is a good chance it is not future proof.
      @jdaviescoates A good idea. I think part of it is how easy it is to navigate while on a smartphone as well.
      • S seeker
        @ruihildt
        @seeker said in Trilium - hierarchical note taking application with focus on building large personal knowledge bases:
        I most just use Nextcloud Text docs! 😛
        S 1 Reply Last reply
          S
          S
          seeker
          @jdaviescoates Do you highlight, share and then post to the Next cloud doc?
          • S seeker
            @seeker no I don't do any highlighting. I just take notes in the Nextcloud Text app (but it do it locally just using gedit)
