  3. Trilium - hierarchical note taking application with focus on building large personal knowledge bases
25 Posts 11 Posters 14.6k Views 12 Watching
  • necrevistonnezrN Offline
    Homepage: https://github.com/zadam/trilium
    Screenshots: https://github.com/zadam/trilium/wiki/Screenshot-tour
    Docker server installation: https://github.com/zadam/trilium/wiki/Docker-server-installation
    Features
    • Notes can be arranged into arbitrarily deep tree. Single note can be placed into multiple places in the tree (see cloning)
    • Rich WYSIWYG note editing including e.g. tables and images with markdown autoformat
    • Support for editing notes with source code, including syntax highlighting
    • Fast and easy navigation between notes, full text search and note hoisting
    • Seamless note versioning
    • Note attributes can be used for note organization, querying and advanced scripting
    • Synchronization with self-hosted sync server
    • Strong note encryption with per-note granularity
    • Relation maps for visualizing notes and their relations
    • Scripting - see Advanced showcases
    • Scales well in both usability and performance upwards of 100 000 notes
    • Touch optimized mobile frontend for smartphones and tablets
    • Night theme
    • Evernote and Markdown import & export
    Builds
    Trilium is provided as either desktop application (Linux, Windows, Mac) or web application hosted on your server (Linux).
    • If you want to use Trilium on the desktop, download binary release for your platform from latest release, unzip the package and run trilium executable.
    • If you want to install Trilium on server, follow this page.
      • Currently only recent Chrome and Firefox are supported (tested) browsers.
    ? 1 Reply Last reply
    • technotameT Offline
      technotameT Offline
      technotame
      This looks great, I'd love this on Cloudron.
      • ultravioletU Offline
        ultraviolet
        I have packaged this for Cloudron. I have been using the desktop version for sometime and the Cloudron app is the natural extension of the app. Providing a web interface and the full sync capability to and from the desktop app.
        Repo is here
          Features
          • Night theme
          Builds
          ? Offline
          ? Offline
          [[global:former-user]]
          @necrevistonnezr
          For "Trillium" read "Trilium" --- please edit this issue title accordingly.
            @ultraviolet thanks! i have marked this app as wip
            ultravioletU 1 Reply Last reply
            • ? Offline
              ? Offline
              I did a little research. As far as I can see, it could not handle PDF files. just images. Am I right or did I miss something?
              • ? [[global:former-user]]
                ultraviolet
                @Captain-Kirk nope it can manage pdf files too. Attach to notes it can't render them but you can version control open and download pdfs.
                • ultravioletU ultraviolet
                  ? Offline
                  ? Offline
                  @ultraviolet Thanks! That would be enough for me.
                    ultraviolet
                    @girish I think this app is ready to roll for some more testing if you want to take the package for pushing to the store?
                      @ultraviolet Yup, it's mind my list. Currently, finishing up vault.
                        @ultraviolet Can you put in the license in this repo as well? I will take a look tomorrow and publish it.
                          ultraviolet
                          wrote on last edited by ultraviolet
                          @girish will do sorry thought I had.
                          EDIT: license added to repo
                            @ultraviolet Thanks! Published as unstable. New repo is at https://git.cloudron.io/cloudron/trilium-app . You should have access already.
                            • S Offline
                              S Offline
                              seeker
                              Is anyone using this?
                              imc67I ruihildtR 2 Replies Last reply
                              • S seeker
                                imc67I Offline
                                imc67I Offline
                                imc67
                                @seeker yes, I use it almost daily for capturing my notes during configuration changes / development in different “code languages” to create my own wiki with “how did I do that?” Also lists of frequently used commands etc.
                                • S seeker
                                  ruihildtR Offline
                                  ruihildtR Offline
                                  ruihildt
                                  @seeker Also using it. All my notes in there.
                                  S 1 Reply Last reply
                                  • ruihildtR ruihildt
                                    S Offline
                                    S Offline
                                    seeker
                                    @ruihildt @imc67 Thanks. I do wish it had an android app. I guess I could copy to the Trillium using the web login. I am also considering joplin, which seems more rubust. Did either of you look at that?
                                    marcusquinnM ruihildtR 2 Replies Last reply
                                    • S seeker
                                      marcusquinnM Offline
                                      @seeker Joplin is the best of the FOSS option IMHO.
                                      Personally, I'm all-in on Ulysses but that's Mac & iOS only, and closed-source and paid if that's an issue.
                                      Otherwise, iA Writer is the best of the cross-platform, offline apps, bunch that I know of.
                                      My main requirement is the .mk files retain their file names and folder structures in a way I can edit with multiple apps as needed, which Joplin doesn't do.
                                      Atom / VS Code and a Git app like Working Copy is another way.
                                      • marcusquinnM marcusquinn
                                        S Offline
                                        S Offline
                                        seeker
                                        @marcusquinn I see. I can imagine how keeping the file names and folder structure intact would allow you to use any program to manipulate the files.
                                        • S seeker
                                          ruihildtR Offline
                                          ruihildtR Offline
                                          ruihildt
                                          wrote on last edited by ruihildt
                                          @seeker
                                          When I started using notes, I wanted to have them as text files in order to have them in a simple format and find the editor that would feel the most natural for my workflow.
                                          I have used Joplin, Typora, Zettlr, FocusWriter. And I settled on Joplin for some time. I think I moved out because of sync issues and also because the interface was a bit too terse for my liking.
                                          I then tried Obsidian.md (and its extension) which blew out all of these, but unfortunately is not free software.
                                          This experience changed my priorities, and I moved to Trilium because as it's not text based, you can use advanced workflow (for example, create everyday a note with the current date, but the best is to check out the demo content from Trilium), have notes appearing in multiple place in a tree structure (which I discovered was important for me) and is super scriptable.
                                          Check out this mad person turning Trilium notes into a CMS: https://wingysam.xyz/posts/tePIFQKUbTQ3
                                          I also hoped there would be an android app, but it's not the case. The mobile version is really usable though, so eventually I'd like to help make it a PWA.
                                          jdaviescoatesJ S 2 Replies Last reply
