  2. Nextcloud
  3. Nextcloud Hub/18
Nextcloud Hub/18
nextcloud
27 Posts 9 Posters 11.9k Views 9 Watching
    Interesting. How does this work? The apache/php app spawns a node process? OnlyOffice source code is now part of the backup? So many questions.
      Can confirm this works. The whole plugin is around 709M which will be part of the backup. It seems that the whole app is basically just frontend js, so we don't need a separate server as such.
      • T
        T
        timka
        This is very interesting. Is there a difference comparing security/ speed/ future support?
        I totally don't mind which one to use. 😊
        Thank you for all your work 👍
        • jdaviescoatesJ
          I note that on https://apps.nextcloud.com/apps/documentserver_community it states:
          The community document server is designed to make it easy to get OnlyOffice running in a Nextcloud instance without the need to setup an external document server, the community document server does not support all features of the official OnlyOffice document server and does not provide the same performance and scalability. (bold added)
          And I'm guessing that the Cloudron app at https://cloudron.io/store/com.onlyoffice.coudronapp.html installs the full version? Is that right @nebulon @girish ?
          So the method described by @gloes (thanks!) works, but perhaps does not have as the same features, performance and scalability?
          So the current method of installing both Nextcloud and ONLYOFFICE Cloudron apps may still be best?
          • necrevistonnezrN
            necrevistonnezrN
            Please update the app to 18.0.1., lots of fixes.
              The update is already rolled out. We just do it slowly for Nextcloud since in the past, Nextcloud updates caused lots of support requests on our side.
                necrevistonnezrN
                necrevistonnezrN
                @nebulon said in Nextcloud Hub/18:
                I'd rather hurry, there are security advisories out: https://adv-archiv.dfn-cert.de/adv/2020-0324/
