  3. RSSbox
RSSbox
5 Posts 2 Posters 2.2k Views 2 Watching
  • rmdesR Offline
    rmdesR Offline
    rmdes
    I have tried to package this for Cloudron but I stumble in different issues that I don't know how to go around, but first a bunch of links about RSSbox :
    demo : https://rssbox.herokuapp.com/
    code : https://github.com/stefansundin/rssbox
    docker image : https://hub.docker.com/r/stefansundin/rssbox
    I have followed basic packaging instruction just to see how far I would go into the packaging process and I got it to install on my cloudron, but then the app cannot properly boot itself because it needs to write files and we have read-only file system.
    So I guess it's about symlinking where rssbox wants to write to a place it can actually write in the cloudron context, how do I do that ?
    Log files : https://paste.armada.digital/upunaxihut.bash
    I think I'm not far from making it running, I don't know about tests to be able to implement that, and probably the healthcheck part also need some love
    Advice welcome 🙂
      Errno::EROFS: Read-only file system @ dir_s_mkdir - /app/tmp/prometheus
      so it looks like tmp needs to be defined
      rmdesR 1 Reply Last reply
        rmdesR Offline
        rmdesR Offline
        rmdes
        @robi Is this defined on the cloudronmanifest or somewhere else ?
          check the app config file first..
          if there's no variable or setting there then create a symlink for it and keep going.. there may be more errors after this one.
            Any further progress on this @rmdes ?
