  2. Ampache
  3. Ampache - How to add a catalog / media with custom storage?
Scheduled Pinned Locked Moved Solved Ampache
25 Posts 4 Posters 15.2k Views 5 Watching
    @jdaviescoates yeah, it's a bit rough.. AFAIK, fixing permissions cannot be done for ext4 mounts without a chmod and I don't know if it's a good idea to do this automagically since it changes the metadata on the external disk. Maybe someone else can chime in.
    Is yours a ext4 volume or something else? Because others like CIFS support umask flag when mounting. Maybe that's an option too.
    Super Fan
    @girish said in Ampache - How to add a catalog / media with custom storage?:
    Yeah it's CIFS
      Yeah it's CIFS
      @jdaviescoates Maybe you can try file_mode and dir_mode flag in the /etc/fstab. See https://askubuntu.com/questions/313093/how-do-i-mount-a-cifs-share-via-fstab-and-give-full-rw-to-guest .
      I guess this is part of the complexity in implementing this 🙂 Worth automating!
      • C
        C
        cocconat
        @girish
        I have a similar problem of @necrevistonnezr here.
        I installed Ampache with the docker, although I am not familiar with the docker infrastructure, nor with the issue that can arise with it.
        My docker is in /home/cocconat/ampache/
        Once I installed the service all run smooth, and I can add the two test songs in the /home/cocconat/ampache/data/media/
        All amazing.
        Now I would like to add to the Catalog my entire music library. It lives in an external storage mounted in /home/cocconat/data/Music
        I tried to make a link to the folder with
        sudo ln -s /home/cocconat/Music ampache/data/media/music
        but the catalogue does not see the linked folder,
        I also tried to add a custom path in the Admin -> Add Catalog, I chose Local catalog and use the abs path of my folder /home/cocconat/data/Music or the relative path ../../Music which seems a bit silly ehehe.
        Anyway, no way to find this folder.
        My storage is an exfat mounted with fstab options: defaults,uid=1000,gid=1000,umask=022 0 1
        which should be fine if I do not want to upload/change the files.
        Is this a problem? shall I add www-data to my group?
        And how am I supposed to add the folder? via the link or somehow else?
        Thanks,
        cocconat
        • C cocconat
          @girish
          All amazing.
          Thanks,
          cocconat
          @cocconat this is the Cloudron forum for the Ampache package, so things which are being discussed are Cloudron related or specific to Ampache package. They may or may not work for docker deployments.
          You might want to take this up upstream here - https://github.com/ampache/ampache/discussions
          C 1 Reply Last reply
            C
            C
            cocconat
            @girish Thanks 🙂
