  2. Kutt
  3. Fast simple White Label?
Scheduled Pinned Locked Moved Kutt
6 Posts 3 Posters 3.1k Views 5 Watching
  • D Offline
    D Offline
    derin
    anyone know of an easy way to change the logo and maybe the button css. Fast and easy. (just getting my frontend dev feet wet sorry if its a basic question.)
      @derin generally, this is possible only if the upstream app itself supports it (which in this case, it doesn't appear to, but you should double check with the kutt authors on github). alternately, you have to package a custom app that contains kutt with the necessary source code changes.
      • D Offline
        D Offline
        derin
        I was afraid of that. I was seeing if the API supported user creation, but it doesn't seem to either. Darn.
        Call out to anyone interested in helping with a custom white label kutt package. I'll get more info from the Kutt devs.
        Thanks
        D 1 Reply Last reply
        • D derin
          Thanks
          D Offline
          D Offline
          derin
          Looks like theme customization is waiting to be merged into the main branch so it will likely be in an upcoming release...
          https://github.com/thedevs-network/kutt/pull/379
          • K Offline
            K Offline
            kallados
            wrote on last edited by kallados
            Some customization would be really amazing. Kutt is nice app. But i can change nothing. Logo or Title of Website at least would be great.
            • K kallados
              @kallados Can you report this upstream https://github.com/thedevs-network/kutt/issues ? If they make this customizable, it should be straightforward after that.
