  2. Calibre Web
  3. Calibre Web database location is not stored persistent
Scheduled Pinned Locked Moved Solved Calibre Web
6 Posts 2 Posters 3.1k Views 2 Watching
  • imc67I Offline
    imc67I Offline
    imc67
    For the second time in a few weeks I discovered that a mounted Volume, configured in Calibre Web (/media/books/library) is replaced after server reboot (?) with a default location /app/data/library ?!
    • imc67I Offline
      imc67I Offline
      imc67
      @girish I just updated the app and again the path to Library is reset to default instead of the manually added Volume 😔
      • imc67I imc67
        @imc67 Indeed, that's a bug. There's no tests for the app yet since it's still unstable, so we didn't manage to catch this one.
          I have pushed a new version that shouldn't overwrite the directory. @imc67 can you please check, thanks ?
          imc67I 1 Reply Last reply
            imc67I Offline
            imc67I Offline
            imc67
            @girish yes! Solved, thank you very much.
            For me the app is working fine since the start, so wondering why unstable?
            • imc67I imc67
              @imc67 Need to write tests and better LDAP integration. The upstream author told me he would accept a PR, so I just need to learn some python and find some time to code it.
              • O odie referenced this topic on
