  2. Rocket.Chat
  3. Rocketchat - custom envs on running instance
Scheduled Pinned Locked Moved Solved Rocket.Chat
9 Posts 3 Posters 3.3k Views 3 Watching
  • P Offline
    P Offline
    parhelium
    wrote on last edited by parhelium
    In docs I found information:
    You can set custom environment variables using cloudron env.
    How I can set custom envs for RocketChat instance already running?
    I see it is possible here:
    https://docs.cloudron.io/custom-apps/cli/#environment-variables
    However can I define custom ENVs in cloudron dashboard ?
    • girishG Do not disturb
      @parhelium I have published a new package 2.13.1. You can edit /app/data/env to add custom vars.
        There is currently no UI for setting those as it is more tailored towards using Cloudron as a deployment platform for app developers.
        What is the use-case for Rocket.chat here? Just to understand what can be set so we can see how to support that in a way we can also test that for updates.
          P Offline
          P Offline
          parhelium
          @nebulon
          The general architecture is to install apps on our client's request on cloudron and every app is integrated with our app.
          Example:
          Instead of reinventing the wheel and writing chat from scratch we are going to embed chat ( RocketChat or Mastodon, etc ) in our app.
          Next phase would be to install custom bots on the same instance of cloudron. In the end we will have X ( 2-10 ) apps installed on cloudron which are integrated and cloudron help us take care about installing, certificates, users management, backup&restore.
          We have also ability to setup separate cloudron for each client.
            I see, however where do the ENV variables come into play specifically for Rocket.chat? I would assume using some Rocket.chat REST API for setting up the integration might be more useful.
              P Offline
              P Offline
              parhelium
              @nebulon
              We need CREATE_TOKENS_FOR_USERS=trueto login properly users in Rocket.Chat from another app.
                Is there any harm in enabling that variable by default in the app package?
                  From my reading of https://github.com/RocketChat/Rocket.Chat/issues/16159, setting that env will allow normal users to use the API. @nebulon maybe we can just source in a env file on startup to make this easier?
                    Good idea, I think that makes most sense. I wasn't able to quickly find any document listing all available env vars for RocketChat. If such a document exists, might be good to add to our docs then.
