  2. Easy!Appointments
  3. Easy!
Easy!
Scheduled Pinned Locked Moved Solved Easy!Appointments
4 Posts 2 Posters 2.8k Views 2 Watching
  • marcusquinnM
    marcusquinnM
    Just gave this App a spin - very nice & simple! Does what it needs to, nothing more 🙂
    I am going to reproduce the same in EspoCRM at some point, hence looking at it for data-structure inspiration - but this is more than good enough for most - and a welcome addition to Cloudron for personal data and time management.
    Thank you whoever did this packaging!
    Minor preference; I would like to be able to change the bottom-right link from "Backend Section" to something nicer, like "Admin" - guess that's an upstream request if relevant.
    Otherwise, a very nice implementation to get rid of Calendly finally.
      Yes you would have to report that upstream to change the button label.
      Otherwise was it stable enough? From my side the packaging would be done, so I think we can mark it as stable then.
        marcusquinnM
        marcusquinnM
        @nebulon Yep, all worked perfectly. I'd call that stable.
        Obviously LDAP would be awesome but I guess also an upstream issue.
        Much appreciate having Easy! available though, thank you for working on that!
        • marcusquinnM marcusquinn
          @marcusquinn yes LDAP is also an upstream issue for the moment.
          I marked the app stable now and released a v1 package
