  3. Retired AWS Instance - Unknown Issue
aws
7 Posts 2 Posters 3.5k Views 2 Watching
  • S Offline
    S Offline
    scuba9273
    Got notified my instance hardware was compromised, which forced a shutdown. After restart, I can see cloudron is still installed (I use InstanceConnect, not SSH) but am unable to get the cloudron dashboard to load.
    Following the basic troubleshooting I get this...
    Then [systemctl status box] returns:
    I have checked that DNS hostnames and resolutions are indeed enabled for my VPC on AWS.
    I also tried restarting the box, but was asked for a password, which I don't know what it would be.
    My skill level with AWS and Cloudron is, at best 3/10. Hoping someone can see where I'm going wrong here!
    • S scuba9273
      nebulonN Away
      nebulonN Away
      @scuba9273 hi and welcome here.
      For a start, can you run the star.sh script with sudo as it requires root access.
      Then we can hopefully see some more issues.
      S 2 Replies Last reply
        S Offline
        S Offline
        scuba9273
        @nebulon Thanks for the quick reply!
        Do you mean start.sh? I have not spent much (any) time using dockerfile etc since I just installed cloudron straight onto my instance and haven't poked around much.
        Using the browser-based SSH, I am root, though. I was able to set a password and restart the box, and one of the host issues w/ yellowtent did resolve... but no fix.
          S Offline
          S Offline
          scuba9273
          @nebulon I think I did what you asked... Here's the gist.
          • S Offline
            S Offline
            scuba9273
            I think I may have found the issue? When AWS retires hardware, on restarting the instance, a new public ipv4 address is generated. Pinging the new one shows this text on the page...
            You are seeing this page because this domain points to Cloudron server IP but no app is installed on that domain.
            If I change all the A records in godaddy, maybe that will solve? Or do I need to alter some config files within cloudron box?
            S 1 Reply Last reply
            • S scuba9273
              S Offline
              S Offline
              scuba9273
              wrote on last edited by scuba9273
              THIS SOLVED IT
              1. AWS instance restarted - new public ipv4 issued
              2. Update new A records in DNS with new ipv4
              3. SSH into instance and run migration command and restart box
              Be sure to purge your browser like the troubleshooting docs say: "You may have to purge the site from your browser's history to get over HSTS certificate issues."
              BACK IN BUSINESS thanks for your help @nebulon
              • S scuba9273
                THIS SOLVED IT
                nebulonN Away
                nebulonN Away
                @scuba9273 glad you figured it out and thanks for sharing the solution!
