  2. Jitsi
  3. Installation: First attempt with an error. Second attempt without a problem
Scheduled Pinned Locked Moved Solved Jitsi
2 Posts 2 Posters 859 Views 2 Watching
  • luckowL
    luckowL
    luckow
    An error occurred during the install operation: Task Error: Task 9940 crashed with code 1 and signal null
    Maybe this from the logs?!
    BoxError: ER_DUP_ENTRY: Duplicate entry '172.18.16.18' for key 'containerIp'
        at updateWithConstraints (/home/yellowtent/box/src/apps.js:865:55)
        at processTicksAndRejections (internal/process/task_queues.js:95:5)
        at async Object.update (/home/yellowtent/box/src/apps.js:874:5)
        at async updateApp (/home/yellowtent/box/src/apptask.js:64:5)
      Ah that is actually not a jitsi issue, but a platform bug. I have seen that sometimes during e2e tests, but so far I wasn't able to reproduce this reliably. As you mentioned a retry usually works then. Something with docker recycling container IPs.
