  3. Cryptomator Hub - zero-knowledge key management solution that allows you to manage access to your vaults
2 Posts 2 Posters 1.6k Views 3 Watching
  • necrevistonnezrN Offline
    From the makers of Cryptomator: Cryptomator Hub
    Video:
    Cryptomator Hub adds zero-knowledge key management for teams and organizations to Cryptomator. It easily integrates into your existing identity management incl. OpenID Connect, SAML, and LDAP. As usual, your favorite cloud service remains your free choice.
    Cryptomator Hub depends on Keycloak, an open-source identity and access management solution. That means, Hub manages access to your vaults whereas Keycloak manages users, groups, and authentication. In the Setup Wizard, you will have the option to choose between deploying Keycloak alongside Hub or specifying an URL to an existing Keycloak installation.
    When Cryptomator Hub is freshly installed, it comes with a community license. This license is valid for 5 seats. Only users assigned to a vault will occupy a seat.
    Docs: https://docs.cryptomator.org/en/latest/hub/setup/
    Setup Wizard: https://cryptomator.org/hub/setup/
    • subvenS Offline
      subvenS Offline
      subven
      Cryptomator is the best FOSS solution I found while searching for ways to encrypt+mount folders/drives and share access among users. I ended up running Cryptomator Hub on a Synology Diskstation. Would appreciate to have it as a tool on Cloudron.
      • S SailReal referenced this topic on
