  2. Nextcloud
  3. [💡 Guide] How to move Nextcloud to an encrypted volume
12 Posts 4 Posters 5.6k Views 5 Watching
  • 32463
    32463
    3246
    wrote on last edited by 3246
    Hi folks, I am playing with Nextcloud some more and wanted to move an app to an encrypted volume without the root volume being encrypted. Please see my other post on how to encrypt the entire Cloudron. I'm sharing this with you in case you find it useful and look forward to your comments.
    *** This guide comes without warranties and is not supported by Cloudron - Caveat emptor! ***
    Step 1: Install cryFS
    See https://www.cryfs.org/tutorial for more details on this awesome Open Source project. I have chosen it because of how easy and lightweight it is. Let me know which other ways you have tried or can recommend.
    sudo apt update && sudo apt install cryfs
    Step 2: Create a folder and mount it
    In this example, I am creating the place where the data is actually stored in /root/baseDir and mount it to /mnt/nextcloud
    You can choose what ever suits your needs and if the baseDir folder is not already in existence it will prompt you to have it created.
    sudo cryfs /root/baseDir /mnt/nextcloud -o allow_other
    Step 3: Create a sub-folder to store your data in
    The reason for this is because we cannot set permissions the way we need to on the mount's root folder.
    sudo mkdir /mnt/nextcloud/data && sudo chown -R yellowtent:yellowtent /mnt/nextcloud/data
    Step 4: Add the volume to Cloudron
    https://your.cloudron.cloud/#/volumes
    Then add your volume using the 'Filesystem' mount type and full path to /mnt/nextcloud/data
    Step 5: Move your Nextcloud app's data directory
    Go to Settings, then Storage for your app and select the volume we created from the dropdown. Hit move and get yourself a cup of tea 🙂
    Notes:
    • Content will be included in your backups
    • You will manually need to mount this volume using the same command as in Step 2 when you restart your Cloudron!
    • This will not protect you from anyone who has root access to your server or to your Nextcloud app. It just encrypts data at rest.
    • Make sure to stop the Nextcloud app before you reboot and disable automatic reboots
    Let me know what you think about this approach and how you keep your Nextcloud secure 🙂
    👉 Find our more www.bebraver.online
    • 32463 3246 referenced this topic on
    • 32463 3246
      Notes:
      @3246 said in [💡 Guide] How to move Nextcloud to an encrypted volume:
      Perhaps improve Step 2 with fstab automounting
      32463 1 Reply Last reply
        32463
        32463
        3246
        @robi that's an idea, although I think it is somewhat insecure to automatically mount the encrypted volume 😉
        • 32463 3246
          @3246 does it ask for a key/passphrase?
            32463
            32463
            3246
            @robi yup. I need to paste in a password to decrypt.
            • 32463 3246
              @3246 right, then it's more about key management than convenience, and what you're actually preventing.
              If the idea is to protect from offline data theft and disk imaging, then it's less relevant if it's (auto)mounted or not.
              As long as it's online & mounted, it's readable.
              Thanks for the great guide!
                32463
                32463
                3246
                @robi you are welcome, glad you found it useful and thanks for your feedback.
                I want to prevent unauthorised access to the volume when the server is offline as well as somebody who might take the server out of its rack and boot it. If the volume automatically mounts, they have full access to the data if they can circumnavigate the login cough recovery mode cough
                That's covering for physical access to the machine, in what likely would be a read-only, forensic access scenario by a 'bad' actor. In my case, it's a virtualised server, so not as likely to matter, unless they move the VM to a dedicated slice to get busy with it.
                Granted, this is somewhat unlikely but being paranoid is better than being sorry 😄
                I am in the UK and storing professional data abroad (in nasty Europe no less - just kidding!) means encryption can cover the requirements nicely (as far as I know - I am not an expert in that field, so somebody please correct me if I'm wrong).
                • andreasduerenA
                  andreasduerenA
                  andreasdueren
                  Hi @3246 Are you still using this setup? I'm interested in how it would work with an externally mounted Storage Box
                    @andreasdueren said in [💡 Guide] How to move Nextcloud to an encrypted volume:
                    I don't think that would be possible as I don't think it's possible to use storage boxes for the data directory
                    Only volumes with Mount Type EXT4 and NFS can be used as the data directory, as other Mount Types do not properly support file permissions.
                    https://docs.cloudron.io/volumes/
                      andreasduerenA
                      andreasduerenA
                      andreasdueren
                      @jdaviescoates I've been using it for my Nextcloud storage directory for a few years without problems now. Highly recommend.
                        storage directory
                        Storage directory isn't the same as data directory though (and I noted "Step 5: Move your Nextcloud app's data directory")
                          storage directory
                          andreasduerenA
                          andreasduerenA
                          andreasdueren
                          @jdaviescoates Yes it's something else. But works well and I have never encountered any problems with Nextcloud and file permissions. This is my setup:
