  2. Package development
  3. Problem Debuging
Problem Debuging
2 Posts 2 Posters 613 Views 2 Watching
  • M
    mateit-cloudware
    Hi There,
    I have a problem debugging:
    If you see the image, you see my steps taken.
    But unfortunately, the tool isn't using the code i pushed back to the application.
    What am I doing wrong?
    • girishG girish moved this topic from Off-topic on
    • M mateit-cloudware
      Hi There,
      @mateit-cloudware Maybe just restart the app after you push the files ? Just use cloudron restart --app ticket ? Is this the LAMP app? There is a byte code cache in place which possibly prevents you from seeing the changes immediately. I think it will update in 60 seconds.
