  2. Ghost
  3. Ghost CMS - Settings not displaying
Scheduled Pinned Locked Moved Ghost
8 Posts 3 Posters 2.2k Views 3 Watching
  • jrl-abstract27J Offline
    jrl-abstract27
    Hi All,
    I use the ghost app and the settings page is not displaying. The error is
    "GET /ghost/assets/admin-x-settings/index-3fd88924.mjs" 404 2ms
    Jan 25 15:16:58NotFoundError: Page not found
    It is the second time that it happen when i reinstall it is all coming back, but do you know why this index file is deleted ?
    London Web Agency : https://abstract27.com/
    • girishG Do not disturb
      Just to double check: have you installed Ghost via Cloudron ?
      Is your app behind Cloudflare or some other proxy?
        jrl-abstract27
        Hi @girish I did install it with Cloudron yes and yes i'm using BunnyCDN
        • jrl-abstract27J jrl-abstract27
          @jrl-abstract27 Can you check if it works if you disable the CDN? Maybe some caching or CSP rule conflict is preventing loading.
          • matix131997M Offline
            matix131997
            While testing CDN in Bunny, I confirm the problem. You need to add a cofiguration to the nginx/apache config file in this case, so that the CDN does not take the "ghost" folder.
            I no longer remember if there is an option in the new version of the Bunny panel, where you can select what folders it should not take.
            The final solution as I wrote above add the config.
            https://www.keycdn.com/support/ghost-cdn-integration
              matix131997
              Okay, I found the option in the new panel. I am currently testing this problem with ghost. So far nothing is happening, but I need to test it after setting the rules. This problem kept showing up hours later after running CDN Proxy
                jrl-abstract27
                I did add rules the below rules.
                What questions me is that i have other ghost apps that works perfectly but this one keep coming back. So i restore backup and it comes back to normal.
                I now disabled the CDN, i will see how it goes.
                  matix131997
                  I see you've found a solution, but you don't just add here, you need to change in other places too. I will add all the possible settings of what you need to set, so that other people know how to set it. Sorry that it took a long time. But my private life has been pounding me 🙂
