  2. Kavita
  3. Host Name setting needs https:// adding to it in order for links in emails to work properly
Scheduled Pinned Locked Moved Solved Kavita
4 Posts 2 Posters 1.0k Views 2 Watching
  • jdaviescoatesJ
    Super Fan
    I reported this upstream:
    https://github.com/Kareadita/Kavita/issues/2878
    But it sounds like it's an issue with the Cloudron package not automatically setting the value correctly to include https://
    Indeed when you manually edit the setting in Admin Dashboard under General you get a warnings saying:
    Host name must start with http(s) and not end in /
      Ah ok , that doesn't match the comment at https://github.com/Kareadita/Kavita/blob/develop/API/Entities/Enums/ServerSettingKey.cs#L116 which says " /// The Host name (ie Reverse proxy domain name) for the server. Used for email link generation" . Host name should not be https. Let me test this and I will update the issue upstream.
        https://github.com/Kareadita/Kavita/blob/8d77b398b2e82fa02d24157dff4c01354b12e5a3/UI/Web/src/app/admin/manage-settings/manage-settings.component.ts#L64 says it has to start with http or https
          Fixed now.
