  3. CiviCRM | Open source constituent relationship management for non-profits, NGOs and advocacy organizations
31 Posts 18 Posters 13.7k Views 16 Watching
  • scookeS
    scookeS
    scooke
    #21
    I tried. Failed. There is some mix up that I can't unravel between the installation directory and final URL. I tried installing with the pertinent items in /app/data/public, using crm.example.com, and even though the install said it worked, I couldn't login because it was looking for crm.example.com/civicrm. So I emptied the db and started again, this time using /app/data/public/civicrm, but that time it seemed to want to just use crm.example.com; a partial admin login appeared if I used crm.example.com/civicrm, but after pressing Enter the page wouldn't load and a message about some problem popped up. Bizarre. I really don't feel like trying again. All permissions were fine. I've already uninstalled the LAMP app. Oh well.
    luckowL 1 Reply Last reply
    • scookeS scooke
      luckowL
      luckowL
      luckow
      #22
      @scooke quick & dirty:
      • install LAMP on your Cloudron
      • open the webterminal
      • cd /app/data/
      • wget https://storage.googleapis.com/civicrm/civicrm-stable/5.80.1/civicrm-5.80.1-standalone.tar.gz
      • tar -xzf civicrm-5.80.1-standalone.tar.gz
      • rm -rf public civicrm-5.80.1-standalone.tar.gz
      • ln -s civicrm-standalone public
      • chown -R www-data: civicrm-standalone public
      Open civicrm.example.com. Install CiviCRM.
      Credentials for mysql -> (easiest way) open credentials.txt in the filemanager
      L jdaviescoatesJ 2 Replies Last reply
      • scookeS
        scookeS
        scooke
        @luckow Instead of ln -s to /app/data/public, I extracted the tar to that directory. Permissions were all fine.
        So you're saying you have it up and running? Because I did essentially what you outlined, and it didn't work.
        imc67I 1 Reply Last reply
        • scookeS scooke
          imc67I
          imc67I
          imc67
          @scooke said in CiviCRM | Open source constituent relationship management for non-profits, NGOs and advocacy organizations:
          I did exactly step by step what @luckow wrote and had it up and running within a minute. Though I didn’t manage to get the cron working and didn’t liked the UI so waiting for v6.
          • scookeS
            scookeS
            scooke
            Well, geez, now I gotta try again.
            • luckowL luckow
              • cd /app/data/
              @luckow said in CiviCRM | Open source constituent relationship management for non-profits, NGOs and advocacy organizations:
              Thanks for this, but I wasn't able to complete it.
              For "open civicrm", you can just click on the GLAMP (LAMP) application in cloudron and it will take you to the CiviCRM page.
              There were errors which meant the civicrm wasn't installable. I am not sure how to proceed
              • luckowL luckow
                • cd /app/data/
                @LoudLemur said in CiviCRM | Open source constituent relationship management for non-profits, NGOs and advocacy organizations:
                Looks like perhaps you didn't give it the correct mysql credentials to me:
                scookeS 1 Reply Last reply
                  scookeS
                  scookeS
                  scooke
                  #28
                  @jdaviescoates @LoudLemur Most ikely it is the server bit. The default is 127.0.0.1:3306 but that is replaced with mysql
                  EDIT: i tried again and it once more didn't work. I can't even access the /phpmyadmin to empty the db to retry without having to install.
                  The error this time, in the logs, was a table not being found. But, it failed as soon as I pressed INSTALL, and gave me a 500 error. I will try one more time, fresh.
                  • scookeS
                    scookeS
                    scooke
                    #29
                    3rd times a charm. THIS time, I choose "Allow all users" rather than just my specific user. THEN I increased the memory in the Cloudron app dashboard to 2GB, AND I edited the php.ini to reflect the same, then restarted. AND instead of just writing mysql in the db location I typed mysql:3306. So which ensured it worked this time? Who knows.
                    SPOKE TOO SOON. I had forgotten to edit the admin user fields, and pressed Install. It alerted me to this... but continued with the install! So I filled in the fields even though the spinning activity wheel was present (Chrome on a Mac). A few minutes later, as I was logged in somehow and editing the details for my company, it all crashed with a note about a fatal db error. I will try ONE MORE TIME, and if it still doesn't work, I'm turning my back on this infernal app.
                    • L
                        Hello @loudlemur
                        As discussed before here https://forum.cloudron.io/post/118000.
                        Please don't post AI output plain into the forum.
