  3. Cronjobs not running
cron
3 Posts 2 Posters 1.5k Views 2 Watching
  • T
    T
    thoresson
    I posted about a problem with Castopod earlier today, but I just realised that my Cloudron instance might have generic cronjob problem: For a couple of weeks, my FreshRSS installation has stopped updating automatically. I've to make a manual refresh every time I want to check my feeds.
    Could it be that my Cloudron have some app-wide cron problem?
    Thanks!
      The cronjobs are managed via the main Cloudron service (called box) maybe something got stuck there, can you try to run systemctl restart box via SSH and see if this resolves the situation?
      • T
        T
        thoresson
        I rebooted the whole system, and it seems to have solved the problem.
