  3. act_runner: A runner for Gitea based on act.
5 Posts 2 Posters 2.6k Views 4 Watching
  • LanhildL Offline
    LanhildL Offline
    Lanhild
    Used in the context of Gitea Actions, their version of GitHub Actions.
    From the fact that Cloudron is used by many to reduce costs (by renting less VPSs), it'd be pretty useful to be able to host such an application on Cloudron.
    I've made a package of the binary @ https://github.com/Lanhild/act-runner-cloudron. Though, some aspects that bring issues:
    • Can't have a proper healthcheck (I have no idea what the binary uses as a port)
    • 2 runtime options; Docker or binary. They suggest to use the docker option. Though, it needs access to the docker socket.
    • Runner registration to Gitea instance; the runner has to "register" to a Gitea instance using a token provided by the latter. Then the runner pings the instance and checks to validate the response.
    This last point has to be done before the initial startup, as the daemon of the binary cannot run without a valid .runner registration file.
    https://gitea.com/gitea/act_runner
    LanhildL 1 Reply Last reply
    • LanhildL Lanhild
      LanhildL Offline
      LanhildL Offline
      Lanhild
      @Lanhild
      I have solved this issue by checking if the registration file exists. If it doesn't, I simply start the runner's cache-server. The instruction to register the runner is explained in the post install message.
      • LanhildL Lanhild
        @Lanhild
        LanhildL Offline
        LanhildL Offline
        Lanhild
        wrote on last edited by Lanhild
        @Lanhild I'm still having issue with the healthcheck, though.
        Solved it by removing an unused param
        • LanhildL Lanhild
          @Lanhild Mighr help to specify the parameter and how to omit it
            LanhildL Offline
            LanhildL Offline
            Lanhild
            @robi was actually a parameter in the startup file. It's all updated in my repo that I've linked previously in this topic.
