  2. Off-topic
  3. Picking Teams for a Tournament
teamtournamentgaming
12 Posts 4 Posters 4.6k Views 4 Watching
  • L Offline
    L Offline
    How would you help do this with software.
    For example, at school, you would line up in front of two players who would take turns to choose members for their team.
    • nebulonN nebulon moved this topic from Discuss on
    • M Offline
      M Offline
      malvim
      Put everyone’s name in, choose the “captains” and have they draft names for their teams? Is that what you have in mind?
      L 1 Reply Last reply
      • M malvim
        L Offline
        L Offline
        @malvim something like that but perhaps with an option to see who is already in a team before they join it
        scookeS 1 Reply Last reply
        • L LoudLemur
          scookeS Offline
          scookeS Offline
          scooke
          @LoudLemur But the point of choosing teams (by one or two ppl only) is to aim for balance. Letting those getting picked the option to decide negates the supposed balance.
          Anyway, you could try using something like Vikunja, or anything else that uses Kanban. I already do this with my domains. I make a Project called WEB, and in Kanban view, I make buckets. The buckets are the various VPSes I have. Then I make a new task in any given bucket. The Task is my domain name. I add tags such as Registrar, App, and Server, and use Notes to include info about the current app. I move my domains around often, so it's a visual cinch to just drag the Task/Domain from Bucket1(VPS1) to Bucket2(VPS2) or Bucket3(VPS3). Each bucket has an extra task containing details about that specific server. EVERY Task also has a Due Date which corresponds to the expiry date of the domain or server. Easy reminders!
          How this can transfer to you is that you make a project called GAMES or TEAMS, and under it two Buckets, each for one person who will be choosing (Or just Captain 1 or Captain 2 if these people need their names in the Pool). Then, make a bunch of Tasks, maybe start in a neutral 3rd Bucket called Pool, and then as people are chosen you simply move their Task with their name from Pool to the appropriate Bucket1 or Bucket2. Everyone can also see who has moved where.
          Good luck!
          • scookeS scooke
            Good luck!
            L Offline
            L Offline
            @scooke hey, thanks!
            I love how you use kanbans to organize domains etc. That is so ingenious!
            I never thought of kanbans for this task.
            I wonder if there is a way to tag rather than bucket like this. Eg time zone, or language
            humptyH 1 Reply Last reply
            • scookeS Offline
              scookeS Offline
              scooke
              Well, Kanban is just a visual way to track progress or process, but I thought why not make my own Buckets, I don't have to make each bucket a step foward. I'm visually oriented as it is. Here are some screenshots.
              • scookeS Offline
                scookeS Offline
                scooke
                Here is how it might look for Games:
                Or don't use the title "Captain" just color code it.
                Wekan and KanBoard might have tighter boxes. Vikunja's are rather tall for the info inside - you can see after 7 names the bottoms ones aren't visible. As people change you can then move their Task/name back into the Player list, you can color code who is the new captain for Teams going into Bloodsport Monkey Bars, you can set a Start date on the Task/name to keep track of when someone joined, and if you give everyone their own account they can edit the info in their own task/name!
                I used the following image: Photo by <a href="https://unsplash.com/@schmig?utm_content=creditCopyText&utm_medium=referral&utm_source=unsplash">Anderson Schmig</a> on <a href="https://unsplash.com/photos/a-group-of-people-playing-a-game-of-tennis-ViQZi7AZ9aU?utm_content=creditCopyText&utm_medium=referral&utm_source=unsplash">Unsplash</a>
                • humptyH Offline
                  humptyH Offline
                  humpty
                  +1 Wekan. You can customize things further if you make use of the "rules" under board settings. Like assigning a custom tag "team red" when moving "Mary" from the pool to "captain 1's" list.
                  • L LoudLemur
                    humptyH Offline
                    humptyH Offline
                    humpty
                    @LoudLemur You can assign tags in Wekan either manually or automatically via rules per specified conditions.
                    • scookeS scooke
                      humptyH Offline
                      humptyH Offline
                      humpty
                      @scooke said in Picking Teams for a Tournament:
                      In Wekan, you simply have to scroll to see the rest.
                      • humptyH humpty
                        scookeS Offline
                        scookeS Offline
                        scooke
                        @humptydumpty said in Picking Teams for a Tournament:
                        Same with Vikunja, I was just pointing out that at-a-glance is limited if the list is long.
                        • L Offline
                          L Offline
                          TagSpaces
                          Https://tagspaces.org
                          Supports minio has Docker
