  3. Trying to add an sshfs mounted location as a regular file system volume type in Cloudron
volumessshfs
25 Posts 7 Posters 8.3k Views 6 Watching
  • M
    msbt
    @andreasdueren the setup in this case is based on rclone, is that what you're looking for? Because the regular storage box setup you probably already know of, since you posted in there as well 😉 https://forum.cloudron.io/post/32783
    • M msbt
      andreasduerenA
      andreasduerenA
      andreasdueren
      @msbt Yes the regular storage box setup i'm well familiar with. But that won't work with immich. So you installed rclone and connected via the SFTP backend?
      M 1 Reply Last reply
        msbt
        @andreasdueren yep, I did this to install and configure it:
        curl https://rclone.org/install.sh | sudo bash
        rclone config
        after that, the config will resides in
        ~/.config/rclone/rclone.conf
        and will look something like this (I enabled encryption too, because why not 😉 :
        [backup]
        type = sftp
        host = u123456-sub1.your-storagebox.de
        user = u123456-sub1
        port = 23
        pass = hashed_pwd
        md5sum_command = md5 -r
        sha1sum_command = sha1 -r
        shell_type = unix
        idle_timeout = 0
        [backupcrypt]
        type = crypt
        remote = backup:backup
        mounting:
        mkdir /mnt/backup
        chown -R yellowtent:yellowtent /mnt/backup
        rclone mount backupcrypt: /mnt/backup \
            --crypt-password "verylonghashedpwd" \
            --crypt-password2 "evenlongerhashedpwd" \
            --vfs-cache-mode writes --daemon --transfers 3 --checkers 6 --allow-other
        The last bit was the important one, without it mounting wasn't possible. You should now be able to mount the rclone thing as a volume. For whatever reason it shows the red dot, I'm guessing that's because of the fs. However, I haven't had an issue with that in months. Currently I'm mounting it manually on every machine reboot, but there are ways to mount it automatically.
        • M msbt
          rclone config
          [backup]
          type = sftp
          user = u123456-sub1
          port = 23
          pass = hashed_pwd
          shell_type = unix
          idle_timeout = 0
          [backupcrypt]
          type = crypt
          mounting:
          mkdir /mnt/backup
          andreasduerenA
          andreasduerenA
          andreasdueren
          @msbt nice, thanks! Will have to read out on that. How is speed? Are you using it for immich?
            msbt
            @andreasdueren you're welcome, I forgot to post the Hetzner docs, they also have a bit of information on that. Speeds are fine, never had any issues with various kinds of media.
