  3. Astro Starlight Documentation - How to easily create project documentation using Cloudron Surfer and Gogs
astrostarlightsurfergogstutorial
1 Posts 1 Posters 877 Views 1 Watching
  • L
    This is an attempt to create a helpful tutorial. Feedback would help.
    The idea is to encourage more people to document their projects using Astro Starlight and easily accomplish this using Cloudron.
    Complete Guide: Astro Starlight Documentation with Cloudron (Gogs + Surfer)
    A comprehensive guide to setting up beautiful Astro Starlight documentation locally and deploying it to Cloudron using Surfer for hosting and optionally Gogs for version control.
    Prerequisites
    • Cloudron instance running at my.cloudron.xyz
    • Surfer app installed on Cloudron at surfer.cloudron.xyz
    • Gogs app installed on Cloudron at gogs.cloudron.xyz (optional)
    • Node.js installed locally
    • Git configured locally
    • PowerShell (Windows) or equivalent terminal
    Stage 1: Project Creation and Setup
    Commands
    # Navigate to your desired project location (AVOID SPACES IN PATH)
    Set-Location "C:\Projects"
    # Create new Astro Starlight project with TypeScript strict mode
    npm create astro@latest myastrowebsite -- --template starlight --typescript strict
    # Navigate into project
    Set-Location myastrowebsite
    # Verify TypeScript strict mode
    Get-Content tsconfig.json | Select-String "strict"
    # Install dependencies (if not auto-installed)
    npm install
    # Verify installation works
    npm run build
    Troubleshooting & Notes
    • Critical: Avoid spaces in project paths - use C:\Projects\myastrowebsite not C:\My Projects\My Website
    • TypeScript Check: Must see "extends": "astro/tsconfigs/strict" in tsconfig.json
    • Build Test: Should show "X page(s) built" without errors
    • Common Issue: If npm create fails, try npm cache clean --force first
    • Windows Users: Use PowerShell, not Command Prompt for best results
    • Git Repository: No. Setup manually later
    Stage 2: Content Structure Creation
    Commands
    # Create all directory structure BEFORE modifying config
    New-Item -ItemType Directory -Path "src/content/docs/getting-started" -Force
    New-Item -ItemType Directory -Path "src/content/docs/concepts" -Force
    New-Item -ItemType Directory -Path "src/content/docs/guides" -Force
    New-Item -ItemType Directory -Path "src/content/docs/reference" -Force
    New-Item -ItemType Directory -Path "src/content/docs/advanced" -Force
    New-Item -ItemType Directory -Path "src/content/docs/community" -Force
    # Create all content files with minimal frontmatter
    title: Installation
    description: How to install the project
    # Installation
    Installation instructions go here.
    "@ | Out-File -FilePath "src/content/docs/getting-started/installation.md" -Encoding UTF8
    title: Setup
    description: How to set up the project
    # Setup
    Setup instructions go here.
    "@ | Out-File -FilePath "src/content/docs/getting-started/setup.md" -Encoding UTF8
    # Continue creating all referenced files...
    # (Create files for: concepts/*, guides/*, reference/*, advanced/*, community/*)
    # Verify all files exist
    Get-ChildItem -Recurse src/content/docs/ -Name
    • Critical Rule: Create ALL content files BEFORE modifying astro.config.mjs
    • File Naming: Use lowercase with hyphens: getting-started.md not Getting Started.md
    • Frontmatter: Keep it simple initially - just title and description
    • Common Error: "File not found" during build means a sidebar slug doesn't match an existing file
    • Best Practice: Use minimal content initially, expand later
    Stage 3: Configuration for Subdirectory Deployment
    Commands
    # Update astro.config.mjs for Surfer subdirectory deployment
    // @ts-check
    import { defineConfig } from 'astro/config';
    import starlight from '@astrojs/starlight';
    export default defineConfig({
      base: '/myastrowebsite',
      integrations: [
        starlight({
          title: 'My Astro Website Documentation',
          description: 'Beautiful documentation powered by Starlight',
          social: [
              icon: 'github',
              label: 'Repository',
              href: 'https://gogs.cloudron.xyz/myuser/myastrowebsite'
          editLink: {
            baseUrl: 'https://gogs.cloudron.xyz/myuser/myastrowebsite/src/branch/main/src/content/docs/',
          sidebar: [
              label: 'Getting Started',
              items: [
                { label: 'Introduction', slug: 'index' },
                { label: 'Installation', slug: 'getting-started/installation' },
                { label: 'Setup', slug: 'getting-started/setup' }
            // Add other sections as needed
    "@ | Out-File -FilePath "astro.config.mjs" -Encoding UTF8
    # Test local development server
    npm run dev
    • Critical Setting: base: '/myastrowebsite' - must match your Surfer folder name
    • Local Development: The base setting is ignored locally - localhost:4321 still works
    • Sidebar Slugs: Every slug must match an existing file exactly (without .md extension)
    • Edit Links: Update the baseUrl to point to your Gogs instance
    • Social Links: Use href property, not link
    • Dev Server: Should start at http://localhost:4321/ with beautiful Starlight theme
    Stage 4: Git Repository Setup (Optional)
    Commands
    # Configure git (replace with your details)
    git config --global user.name "Your Name"
    git config --global user.email "your.email@example.com"
    # Initialize repository
    git init
    # Create .gitignore
    # Dependencies
    node_modules/
    .pnpm-debug.log*
    # Environment
    .env
    .env.*
    # Astro
    .astro/
    dist/
    # IDE
    .vscode/
    .idea/
    # OS
    .DS_Store
    Thumbs.db
    # Logs
    *.log
    "@ | Out-File -FilePath ".gitignore" -Encoding UTF8
    # Add remote (create repository in Gogs first)
    git remote add origin https://gogs.cloudron.xyz/myuser/myastrowebsite.git
    # Initial commit and push
    git add .
    git commit -m "Initial commit: Astro Starlight documentation setup"
    git push -u origin main
    • Repository Creation: Create the repository in Gogs web interface FIRST
    • Authentication: You'll be prompted for Gogs username/password
    • Branch Name: Modern Git uses main, older versions use master
    • Push Errors: If "src refspec main does not match any", run git branch -M main first
    • Credentials: Consider using SSH keys for easier authentication
    • Optional Step: Skip this if you don't want version control
    Stage 5: Building for Production
    Commands
    # Build static site
    npm run build
    # Verify build success
    Get-ChildItem dist
    # Check critical folders exist
    Test-Path "dist/_astro"
    Test-Path "dist/pagefind"
    # Optional: Test build locally
    npx serve dist
    • Build Output: Should show "X page(s) built" without TypeScript errors
    • Critical Folders: _astro/ (styling) and pagefind/ (search) must exist
    • Sitemap Warning: "Sitemap integration requires site option" is harmless
    • Build Size: Expect ~20+ pages for a basic Starlight setup
    • Local Testing: npx serve dist lets you test the built site locally
    • Common Issue: Build failures usually mean missing content files or config errors
    Stage 6: Surfer Deployment
    Commands
    # No PowerShell commands - this is done via web interface
    Write-Host "1. Open browser to: https://surfer.cloudron.xyz"
    Write-Host "2. Login with Cloudron credentials"
    Write-Host "3. Create new folder: myastrowebsite"
    Write-Host "4. Upload ALL contents from dist/ folder"
    Write-Host "5. Verify deployment at: https://surfer.cloudron.xyz/myastrowebsite/"
    Deployment Steps
    1. Access Surfer: Navigate to https://surfer.cloudron.xyz
    2. Login: Use your Cloudron credentials
    3. Create Folder: Name it exactly as specified in your base config
    4. Upload Files: Upload ALL contents from your local dist/ folder
      • index.html (homepage)
      • _astro/ folder (critical - contains all CSS/JS)
      • pagefind/ folder (critical - enables search)
      • All documentation folders (getting-started/, concepts/, etc.)
      • 404.html and favicon.svg
    5. Verify: Visit https://surfer.cloudron.xyz/myastrowebsite/
    • No Styling: Usually means _astro/ folder missing or base config wrong
    • Broken Search: Means pagefind/ folder missing
    • 404 Errors: Check that folder name in Surfer matches base in config exactly
    • Upload Methods: Drag-and-drop or use Surfer's upload interface
    • Permissions: Ensure uploaded files are web-accessible
    • Folder Structure: Must preserve exact folder structure from dist/
    Stage 7: Update Workflow
    Commands
    # Daily workflow for updates
    # 1. Edit content files locally
    # 2. Test changes
    npm run dev
    # (Check at http://localhost:4321/)
    # 3. Commit changes (if using Gogs)
    git add .
    git commit -m "Update documentation"
    git push
    # 4. Build for deployment
    npm run build
    # 5. Upload new dist/ contents to Surfer
    Write-Host "Upload new dist/ contents to Surfer folder"
    • Hot Reloading: Local dev server updates instantly when you save files
    • Build Before Deploy: Always run npm run build before uploading to Surfer
    • Incremental Updates: You can upload individual files/folders to Surfer
    • Version Control: Commit to Gogs regularly, deploy to Surfer when ready
    • Backup Strategy: Gogs serves as your backup and version history
    Common Issues & Solutions
    Build Failures
    • Missing Files: Every sidebar slug must have a corresponding .md file
    • TypeScript Errors: Check tsconfig.json has strict mode enabled
    • Import Errors: Ensure all dependencies installed with npm install
    Styling Issues on Surfer
    • No CSS: Check base config matches Surfer folder name exactly
    • Missing Assets: Ensure _astro/ folder uploaded completely
    • Path Issues: Verify all files uploaded with correct folder structure
    Git Issues
    • Push Failures: Repository must exist in Gogs before first push
    • Authentication: Use HTTPS with username/password or set up SSH keys
    • Branch Issues: Modern Git uses main, may need git branch -M main
    Performance Tips
    • Local Development: Keep dev server running while editing
    • Efficient Deployment: Only upload changed files to Surfer after initial deploy
    • Search Functionality: Ensure pagefind/ folder always uploaded for search to work
    Final Result
    You'll have:
    • ✅ Local Development: Beautiful Starlight interface at localhost:4321
    • ✅ Version Control: Source code at https://gogs.cloudron.xyz/myuser/myastrowebsite
    • ✅ Live Website: Production docs at https://surfer.cloudron.xyz/myastrowebsite/
    • ✅ Professional Features: Search, responsive design, dark/light modes
    • ✅ Self-Hosted: Complete control over your documentation infrastructure
    The result is a professional, fast, and beautiful documentation website with a robust development and deployment workflow!
