  2. Collabora Online (CODE)
  3. Collabora Issue Setting Domain
Scheduled Pinned Locked Moved Solved Collabora Online (CODE)
6 Posts 3 Posters 2.8k Views 3 Watching
  • technotameT Offline
    technotameT Offline
    technotame
    Hello,
    I have been having issues getting the Collabora app connected to Nextcloud. I believe the issue is saving the Nextcloud domain in Collabora. When I use the default regex and click "Save", it hangs. The browser console show a constant stream of 502 errors to the URL https://docs.mydomain.com/hosting/discovery, which is the Collabora domain. I've tried reinstalling Collabora multiple times, restarting it, etc., and nothing seems to help.
    Thanks!
    • nebulonN Away
      nebulonN Away
      Do you happen to have any special characters in your domain? The regexp handling in collabora had some issues in the past. By default the collabora app would be setup to allow all apps (nextcloud instances) on the same cloudron domain.
        technotameT Offline
        technotame
        No special characters at all. I've tried reinstalling Collabora and not manually setting the domain, but that gives a error in Nextcloud, "Internal Server Error".
        • nebulonN Away
          nebulonN Away
          That is indeed strange and I am not able to reproduce this. Can you disable all NextCloud addons, besides the Collabora one and try again? Maybe something is interfering there.
          • girishG Do not disturb
            One idea is to see if you can reproduce it at https://my-demo.cloudron.me/#/apps (username: cloudron password: cloudron) and take it from there.
            I also pushed a doc yesterday for collabora, if it helps - https://cloudron.io/documentation/apps/collabora/
              technotameT Offline
              technotame
              I've tried disabling all the other addons in Nextcloud, but no dice. I looked in the logs and there's nothing out of the ordinary.
              Girish, I tried to replicate it on your setup, but I can't find anywhere to enable Collabora. I have the option where the documentation you posted says it should be on my Nextcloud instance, but on yours it's not there.
