  3. Other pricing model for small installation
pricing
6 Posts 4 Posters 3.5k Views 5 Watching
  • R Offline
    R Offline
    roru2k20
    Hello,
    I use Cloudron in two installations and I think I would prefer a different pricing model.
    I would like to install more than 2 apps, but also not more than 5 at the most, so 30 dollars per month is too much for a private installation.
    I think you could do 2 apps for free, if you want to install a maximum of 5 apps, then you buy a one-time license for a small amount and if you want to use Cloudron to its full potential, then you can buy the subscription.
    For example 20-25 € one-time would be an acceptable amount, but I don't want to seem too brazen either. I know such a development was time consuming and expensive and you have to try to get the money back in, but I think a cost/benefit ratio should be reasonable.
      thanks for your feedback on our pricing structure, we keep on iterating on our pricing, so we will take this into consideration.
      Best,
      Johannes
      • JOduMonTJ Offline
        JOduMonTJ Offline
        JOduMonT
        wrote on last edited by JOduMonT
        The price list Cloudron have right now could be fine if you use more application
        Right now I'm using only one application + the mail
        but later I plan to use 3 or max 5 apps.
        I consider maintaining one apps to have access to the dev license but also a better price list would be appreciate
        maybe something like this:
        0-2 = Free
        3-9 = 10$/m
        10-19=20$/m
        20+=30$/m
        • yusfY Offline
          yusfY Offline
          yusf
          There's a dev license?
            We offer a dev license for upstream projects, which develop apps, which can be packaged for Cloudron.
            JOduMonTJ 1 Reply Last reply
              JOduMonTJ Offline
              JOduMonTJ Offline
              JOduMonT
              @nebulon said in Other pricing model for small installation:
              dev license
              and for the dev license, it is one dev license per server/installation ?
