  2. Discourse
  3. Discourse and incoming email
Scheduled Pinned Locked Moved Solved Discourse
discourse
45 Posts 11 Posters 18.7k Views 12 Watching
  • bmannB
    bmannB
    bmann
    Yep, I had no problems with this -- once I figured out enabling POP3 🙂
    • set up forum@yourdiscoursedomain.com as a mailbox
    • enable pop3
    • set the app as the owner of this mailbox
    Want unique addresses for categories? Set up aliases for forum@yourdiscoursedomain.com like myothercategory@yourdiscoursedomain.com
    In Discourse, you'll need to enable email in
    For initial Discourse setup, I also have better instructions:
    Rather than resetting the email address, you can / should reset the password -- which you need to do right away. Run the rake admin:create task from the Terminal for the root / admin account.
    Hit "Y" to reset password and change the password.
    The account already is an admin, and I didn't bother changing the email because I really only see it as a backup account.
    Once I logged in with OIDC with my Cloudron account, I followed this same process to make my account an admin account -- same rake admin:create command, say "Y" to making it an Admin, but don't change password.
    I don't know how to contribute better setup instructions -- are they in git so I can send a PR?
    girishG jdaviescoatesJ 2 Replies Last reply
    • bmannB bmann
      • enable pop3
      @bmann you can submit PRs here - https://git.cloudron.io/cloudron/docs/
      Discourse docs are at https://git.cloudron.io/cloudron/docs/-/blob/master/knowledgebase/docs/apps/discourse.md?ref_type=heads
      • bmannB bmann
        • enable pop3
        @bmann thanks for your input on this, very helpful! I think I'm correct that you never got around to submitting a PR to improve the docs around this? 🤷 🤔
        • bmannB
          bmannB
          bmann
          I did not, unlikely to get to it, sorry.
            @bmann I will take care of this and make sure your advanced guide will be added to https://docs.cloudron.io/apps/discourse/#incoming-email-setup
            Thanks for the already done write-up!
