  3. ejabberd - Robust, Scalable and Extensible Realtime Server using XMPP, MQTT and SIP
24 Posts 9 Posters 12.0k Views 12 Watching
  • L Offline
    L Offline
    Has anybody who might know how to package ejabberd contacted the ejabberd people, yet?
    • D djxx referenced this topic on
    • L Offline
      L Offline
      https://github.com/processone/ejabberd/discussions/4095#discussioncomment-7251934
      • L Offline
        L Offline
        ejabberd has had a lot of work to improve it since it was first requested by @jdaviescoates Lets support it on cloudron, now that we have version 9.
        ## ejabberd Main Improvements Since May 2020
        ### Matrix Gateway (mod_matrix_gw) Enhancements
        - **Initial 1:1 support** (24.02+): Bridging to Matrix servers for direct messages.
        - **Room support** (25.03): Invitations to Matrix rooms, public room joins; MUC-like handling (versions 9-11 initially).
        - **Expanded room compatibility** (25.07/25.10): Older room versions, Hydra rooms (v12), state resolution rewrite, notary_servers/leave_timeout options.
        - **Other fixes**: No empty direct messages, double-colon JID for Hydra.
        ### Spam & Security Filtering
        - **mod_antispam** (25.07/25.10): Replaces mod_spam_filter; RTBL support for blocking spammer JIDs/URLs in messages/subscriptions.
        - **ACME fixes**: Erlang/OTP 28.0.2 compatibility.
        - **XEP-0425**: Moderated Message Retraction (24.12).
        ### New Modules & Discovery
        - **mod_providers** (25.10): Auto-generates/serves XMPP Providers JSON (XEP-0485) at /.well-known/xmpp-provider-v2.json.
        - **mod_pubsub_serverinfo** (25.07/25.10): PubSub Server Information for XMPP network graphs.
        - **mod_antispam**: Real-time block lists.
        ### XEP & Protocol Support
        - **XEP-0431**: Full Text Search in MAM (25.10?).
        - **XEP-0402**: PEP Native Bookmarks (24.12).
        - **XEP-0424**: Message Retraction (24.12).
        - **XEP-0369**: Latest MIX (23.01).
        - **MAM improvements**: archive_muc_as_mucsub option (25.10).
        ### Authentication & Config
        - **Multiple password types** (25.03): Simultaneous support.
        - **auth_password_types_hidden_in_scram1** (25.10).
        - **host_alias**, predefined keywords, rest_proxy options.
        - **ejabberdctl**: CTL_OVER_HTTP (25.03).
        ### API & Admin Tools
        - **New API Commands**: Inspired by XEP-0133 across modules (25.10).
        - **mod_configure**: access option (25.03).
        - **WebAdmin**: Link to Converse, formatting updates.
        ### Performance & Compatibility
        - **Erlang/OTP**: 25 required, 28 supported (25.10).
        - **SQL/MUC changes** (23.01+).
        - **Container images**: Macros, WebAdmin port exposure (25.03).
        ### Other Highlights
        - **Business Edition**: GCM/Webhook/Webpush fixes.
        - **General**: XEP-0313 MAM, HTTP Upload, vCard-temp; systemd integration, JWT auth, MQTT broker maturity (21.01+).
        Sources: GitHub releases (20.06–25.10), changelogs. Focus on user-impacting features; full details per release at https://github.com/processone/ejabberd/releases.
        • L Offline
          L Offline
          #24
