  2. Gitea
  3. Gitea minio storage for lfs
Scheduled Pinned Locked Moved Gitea
27 Posts 7 Posters 33.8k Views 7 Watching
  • W Wirv
    @girish said in Gitea minio storage for lfs:
    You have to omit the curly braces . Maybe you put curly braces in your config? Could that be it?
    I actually tried both ways and the same error
    2023/02/01 16:20:39 ...les/storage/minio.go:91:NewMinioStorage() [I] Creating Minio storage at s3.eu-central-003.backblazeb2.com:build2bit with base path attachments/
    2023/02/01 16:20:39 routers/init.go:59:mustInit() [F] code.gitea.io/gitea/modules/storage.Init failed: Malformed Access Key Id
    Received signal 15; terminating.
    @Wirv It seems that error may be from backblaze b2 and not gitea - https://www.reddit.com/r/backblaze/comments/u9ivrh/malformed_access_key_id/ . The user there succeeded by regenerating the key. Which makes me wonder, does your key have fancy characters like "=" , "/" , "[" or something?
    W 2 Replies Last reply
      W
      W
      Wirv
      @girish unfortunately yes, what do I do, try to regenerate it until a key without special characters comes out?
        W
        W
        Wirv
        wrote on last edited by Wirv
        #23
        @girish now it seems to work, the push takes a long time for a single file of less than a gb (for security inserted in the gitattribute as lfs) but the bucket is empty after the push, I don't understand where to throw it.
        I made sure I removed gitea's default lfs path from the app.ini
        • W Wirv
          @Wirv OK, I don't really know that part since I have never tried LFS myself. I just wanted to get you over the configuration hurdle.
            W
            W
            Wirv
            @girish thank you very much anyway, thanks to you anyway I solved a big problem, I hope someone on the forum can help me conclude or be able to find a solution
            W 1 Reply Last reply
              W
              W
              Wirv
              @girish I finally succeeded! Do you happen to know how multiple repos are managed? Is there a way to diversify buckets per repo or does it handle it well with one bucket for all repos?
              • W Wirv
                W
                W
                Wirv
                @Wirv I did it by setting this to false
                SERVE_DIRECT = true
