  2. Gitea
  3. Database encoding problems
Scheduled Pinned Locked Moved Gitea
7 Posts 2 Posters 20.5k Views 2 Watching
  • R
    R
    Robin
    Long story short, I've got some problems with encoding.
    See the following Github issue: https://github.com/go-gitea/gitea/issues/16016
    Which links to the following solution: Are you using MySQL? If so you probably need to convert the tables to utf8mb4, gitea convert can help with that but take a backup before doing it.
    I don't remember enough about MySQL anymore to know how to look into this myself, but I'm happy to try help test if you want to try hold my hand, @girish 🙂
    • R Robin
      @robin What's a good way to reproduce/test this? Just paste some emojis?
      Cloudron uses utf8mb4 by default in mysql. So, the issue is probably something else.
        On a new gitea install:
        mysql> SHOW VARIABLES LIKE "character_set_database";
        | Variable_name          | Value   |
        | character_set_database | utf8mb4 |
        1 row in set (0.02 sec)
        mysql> show create table webhook;
        | Table   | Create Table        |
        | webhook | CREATE TABLE `webhook` (
          `id` bigint NOT NULL AUTO_INCREMENT,
          `repo_id` bigint DEFAULT NULL,
          `org_id` bigint DEFAULT NULL,
          `is_system_webhook` tinyint(1) DEFAULT NULL,
          `url` text,
          `signature` text,
          `http_method` varchar(255) DEFAULT NULL,
          `content_type` int DEFAULT NULL,
          `secret` text,
          `events` text,
          `is_ssl` tinyint(1) DEFAULT NULL,
          `is_active` tinyint(1) DEFAULT NULL,
          `type` varchar(16) DEFAULT NULL,
          `meta` text,
          `last_status` int DEFAULT NULL,
          `created_unix` bigint DEFAULT NULL,
          `updated_unix` bigint DEFAULT NULL,
          PRIMARY KEY (`id`),
          KEY `IDX_webhook_org_id` (`org_id`),
          KEY `IDX_webhook_is_active` (`is_active`),
          KEY `IDX_webhook_created_unix` (`created_unix`),
          KEY `IDX_webhook_updated_unix` (`updated_unix`),
          KEY `IDX_webhook_repo_id` (`repo_id`)
        ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_0900_ai_ci ROW_FORMAT=DYNAMIC |
        1 row in set (0.00 sec)
        • R
          R
          Robin
          My existing install has this:
          ENGINE=InnoDB DEFAULT CHARSET=utf8 ROW_FORMAT=DYNAMIC |
          So perhaps this might have been a bug that they corrected in a release sometime after I had already installed?
          • R
            R
            Robin
            Searching around their issues, I find this: https://github.com/go-gitea/gitea/issues/11081
            • R Robin
              @robin indeed, looks like old installations had incorrect encoding. Does that gitea convert help? I don't know if ALTER TABLE works. Something like this : ALTER TABLE webhooks CONVERT TO CHARACTER SET utf8mb4 COLLATE utf8mb4_0900_ai_ci;
              • R
                R
                Robin
                @girish Yeah, I ran:
                /home/git/gitea/gitea convert -c /run/gitea/app.ini as user git, and now things seem converted:
                ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_general_ci ROW_FORMAT=DYNAMIC
                On the downside, the convert tool seems to unconditionally convert, and is quite slow, so I guess it can't easily be run as part of the startup process or something 😕
