  3. Does anyone have a more recent, working FORM solution using existing apps on Cloudron?
35 Posts 11 Posters 16.9k Views 9 Watching
    @rmdes said in Does anyone have a more recent, working FORM solution using existing apps on Cloudron?:
    There is a RSS plugin that interest me for Mautic that I want to explore a bit more, I want to see if we could get a RSS powered "newsletter" automated using Mautic, I want to see how far this RSS plugin can go, integrate images etc.. and allow me to generate a newsletter from another activity : curating information / staring items inside Fresh RSS for example / then use the output of only the stared RSS items to feed a Mautic newsletter about a given topic.
    I'm really interested in this sort of stuff too.
    andreasduerenA Offline
    andreasdueren
    I use mautic for contact / newsletter signup. The nice thing is that I can from there generate leads and pick things up with n8n
    • rmdesR rmdes
      @robi not really, the scenarios I have tested are more trivial than really being used,
      like I can get Mautic to send N8 a new subscriber and this in turn is sent via N8 webhook to my matrix dedicated space where I centralize notifications, but this was mainly for testing only I don't really need complex interactions for now.
      The way I use Mautic is pretty default, since a few months the UI editor to compose newsletter is operational and enough for my needs, the possibilities Mautic offer in terms of forms are more than enough for me (I don't need conditional stuff for now, not using it in marketing/profit purpose)
      forms are super easy to integrate (Js, Iframe etc..) and "transparent" enough to integrate any front-end design in my experience: Mautic + Wordpress is smooth combination.
      humptyH Offline
      humptyH Offline
      humpty
      @rmdes what do you use to prevent spam signups/messages?
      rmdesR ei8fdbE andreasduerenA 3 Replies Last reply
      • ei8fdbE Offline
        ei8fdbE Offline
        ei8fdb
        I spend alot of my time making forms, surveys, ways to gather data.
        My suggestions:
        • if you want to make 1 contact form (text input fields, maybe some simple selections from combox, radio buttons) and use that data for something I'd suggest Nextcloud & the Forms app. Forms is perfect for the majority of simple form needs. It spits it out to a CSV and also does simple graphing. But it handles other forms needs well (closing forms after X time, max/min selections). There is simple visual modifications.
        • if you plan to make a lot of form and more advanced forms (all the above plus branching logic - e.g. if you choose answer 2 skip to form page 5, control access to the form) I'd suggest Limesurvey. But be prepared it is not trivial to use. You can modify it visually.
        • if you want to make a simple form for gathering to just gather data and write it to a nicely manipulatable database you, I'd suggest Baserow like others have suggested (e.g. here is a form I created to gather participants names for research. No idea about visual modifications.
        I'd recommend trying nextcloud first. The benefit of cloud storage comes for free and it needs (I think) less resources than the other options.
        • jdaviescoatesJ Offline
          I've not tried it yet, but ONLYOFFICE now has forms too
          https://www.onlyoffice.com/blog/2022/01/7-interesting-facts-about-onlyoffice-forms/
          ei8fdbE 1 Reply Last reply
          • humptyH humpty
            rmdesR Offline
            rmdesR Offline
            rmdes
            wrote on last edited by rmdes
            #25
            @humptydumpty
            Recaptcha for the moment but there is also ways to create native honeyspot hole with Mautic if you don't want to use google.
            https://github.com/KonstantinCodes/mautic-recaptcha
            • rmdesR rmdes
              @humptydumpty
              @rmdes is there a way to do simple math and check for an answer?
              • humptyH humpty
                ei8fdbE Offline
                ei8fdbE Offline
                ei8fdb
                @humptydumpty I've created a lot of forms, and rarely (less than 1%) get spam. I choose to deal with it, when if it becomes a problem. (If the form is going to be live for years, there's a chance spam will become an issue)
                  ei8fdbE Offline
                  ei8fdbE Offline
                  ei8fdb
                  @jdaviescoates From the look of it it looks like the forms are literally fillable documents. 🤦 Have we gone backwards to the days of fillable PDFs?!
                  Thanks for mentioning it. I will try it out. (Tho' I'm not holding my breath!)
                  • humptyH humpty
                    andreasdueren
                    @humptydumpty said in Does anyone have a more recent, working FORM solution using existing apps on Cloudron?:
                    I used to use the google captcha but would still get lots of spam. Now I'm just using a field with a condition where I make people solve a simple math question like "what is 6+1?"
                    humptyH 1 Reply Last reply
                      humptyH Offline
                      humptyH Offline
                      humpty
                      @andreasdueren I've tried math, honeypots, captcha's, black magic, incantations, prayers, and pleading, and I still get spammed on my Wordpress forms. I've even tossed the form inside a pop-up and that didn't deter them 😥.
                      • humptyH humpty
                        andreasdueren
                        @humptydumpty Do you need it to be a wordpress form? I'm using the javascript implementation via mautic and that already excludes everyone who doesn't have Javascript activated
                        humptyH robiR 2 Replies Last reply
                          humptyH Offline
                          humptyH Offline
                          humpty
                          #32
                          @andreasdueren No, it doesn't have to be. The websites are using Wordpress so it was easy to just use of the popular form plugins like Contact Form 7, etc.. I don't mind redirecting users off-site if it means NO SPAM 🙂
                            @andreasdueren said in Does anyone have a more recent, working FORM solution using existing apps on Cloudron?:
                            Can you jot down how to set that up in a separate thread?
                              andreasdueren
                              @robi Sure, however not immediately, one of these days should work. Where should I post it?
                                @andreasdueren good question, the Mautic topic is relevant as is any web hosting app, like Wordpress and Surfer.
                                Perhaps house it in the Mautic section of the forum and mention the rest in the post so it can be found by any of those means. 😄
