  2. Off-topic
  3. Suggestions on track control for markdown
7 Posts 5 Posters 3.5k Views 5 Watching
  • chetbakerC
    chetbakerC
    chetbaker
    Hello folks,
    I would like to know if any of you have thoughts/developments/ideas to sort out one of the critical issues I'm having in a team not using Google Docs: track changes.
    When you are using markdown plain text files -say, using NextCloud-, is there any way to see the differences between 2 recently changed files? I'm thinking more or less in the same way Etherpad shows changes. Example: John and Barry are editing a markdown file. Barry just changed a lot of things and how John would like to see the changes within the document.
    Do you have any thoughts on how to solve this?
    mehdiM jdaviescoatesJ 2 Replies Last reply
    • chetbakerC chetbaker
      Hello folks,
      mehdiM
      mehdiM
      mehdi
      @chetbaker If you're using exclusively markdown files, I would wholeheartedly recommend using good old Git. Yes, it may be a bit less UX-focused, but it's by far the best way to track changes in text files.
      chetbakerC 1 Reply Last reply
      • mehdiM mehdi
        chetbakerC
        chetbakerC
        chetbaker
        @mehdi thanks about that. The thing is my user case is not tech oriented. So, implementing a git based version control doesn’t seem very realistic to me.
        I looked for git apps on Nextcloud and no luck either.
        murgeroM 1 Reply Last reply
          murgeroM
          murgeroM
          murgero
          @chetbaker
          You wont get version control like that in nextcloud I don't think but these apps (in the cloudron app store) can do what you want:
          • bookstack
          • hedgedoc
          • wiki.js
          • mediawiki
          • dokuwiki
          • jingo
          • gitlab
          • gitea
          • gogs
          I probably missed one or two but this should be the bulk - and some of these apps may have Nextcloud add-ons you can install, though a google search may be required for that.
          https://urgero.org
          fbartelsF 1 Reply Last reply
          • murgeroM murgero
            @chetbaker
            • bookstack
            • hedgedoc
            • wiki.js
            • mediawiki
            • dokuwiki
            • jingo
            • gitlab
            • gitea
            • gogs
            fbartelsF
            fbartelsF
            fbartels
            @murgero said in Suggestions on track control for markdown:
            mediawiki
            dokuwiki
            At least these two use their own markup language however.
            I've been using Hedgedoc for quite a while, and also with a fair amount of non-technical people and most seem to sadly struggle with it (I always need to explain to them how to switch from the "share" mode to the editing mode). Apart from that its pretty much like Etherpad, which also comes with the downside that its a collection of single pages and not a structured document storage like a wiki (or even a folder structure like in Nextcloud).
            I would therefore recommend to look more into the wiki like recommendations, even if it means you're loosing same time editing.
            • fbartelsF fbartels
              mediawiki
              dokuwiki
              chetbakerC
              chetbakerC
              chetbaker
              @fbartels Yeah, that's exactly the same situation I had using Hedgedoc. It's a great tool, but not having a way to connect with a shared folder on Nextcloud makes whatever document you are working in an isolated thing.
                Hello folks,
                @chetbaker said in Suggestions on track control for markdown:
                It's not markdown, but you can track changes in ONLYOFFICE docs:
