  3. LDAP not exposing outside
directory
10 Posts 4 Posters 3.6k Views 4 Watching
  • vladimir.dV Offline
    vladimir.dV Offline
    vladimir.d
    It doesn't seem that a long waited feature - the ability to expose LDAP outside is working in our environment after the recent upgrade to 7.1.3.
    For some reason 636 port doesn't get available even locally.
    netstat -tulpn | grep 636 shows nothing, but 3002 port is still there though.
    Also wondering if there is an ability to expose LDAP to a local network only on a specific network interface, e.g. 192.168.10.0/24.
    • vladimir.dV vladimir.d
      girishG Do not disturb
      @vladimir-d said in LDAP not exposing outside:
      This is expected. We use a NAT rule to rewrite queries from 3002 to port 636 (we do this so that the LDAP server can run as non-root for security purposes).
      Are you not able to connect to port 636 by IP address (telnet <cloudron-server-ip> 636) ? Have you opened 636 on the firewall ? When you try to telnet make sure that your PC/Mac is on the IP whitelist.
      Not at an interface level but providing the IP block like you did should work (so you have entered things correctly in the UI AFAICT).
      vladimir.dV 1 Reply Last reply
        vladimir.dV Offline
        vladimir.dV Offline
        vladimir.d
        @girish well, telnet <cloudron-server-ip> 636 started to work today, probably another reboot helped.
        Now I cannot get anything via ldapsearch neither by a local ip nor by <cloudron-server-domain>.
        # ldapsearch  -x -b "ou=users,dc=cloudron" -D "cn=admin,ou=system,dc=cloudron" -W -H ldap://<cloudron-server-domain>:636
        ldap_initialize( ldap://<cloudron-server-domain>:636/??base )
        Enter LDAP Password:
        ldap_result: Can't contact LDAP server (-1)
        girishG 2 Replies Last reply
          the above has to be ldaps:// . Do you get the same error with that?
            @vladimir-d can confirm this works:
            $ ldapsearch  -x -b "ou=users,dc=cloudron" -D "cn=admin,ou=system,dc=cloudron" -W -H ldap://my.cloudron.space:636
            $ ldapsearch  -x -b "ou=users,dc=cloudron" -D "cn=admin,ou=system,dc=cloudron" -W -H ldaps://my.cloudron.space:636
            # extended LDIF
            # LDAPv3
            # base <ou=users,dc=cloudron> with scope subtree
            # filter: (objectclass=*)
            # requesting: ALL
            # uid-0cfbd3d8-6547-4332-9415-dadfe8b78ac4, users, cloudron
            dn: cn=uid-0cfbd3d8-6547-4332-9415-dadfe8b78ac4,ou=users,dc=cloudron
            objectclass: user
            objectclass: inetorgperson
            objectclass: person
            objectcategory: person
              vladimir.dV Offline
              vladimir.dV Offline
              vladimir.d
              wrote on last edited by vladimir.d
              @girish said in LDAP not exposing outside:
              Yes, this works for ldaps://<cloudron-server-domain>:636 but not for local IP ,e.g.
              ldaps://192.168.10.10:636
              By <cloudron-server-domain>:
              # ldapsearch  -v -c -x -b "ou=users,dc=cloudron" -D "cn=admin,ou=system,dc=cloudron" -W -H ldaps://<cloudron-server-domain>:636
              ldap_initialize( ldaps://<cloudron-server-domain>:636/??base )
              # extended LDIF
              # LDAPv3
              # requesting: ALL
              # uid-0430c072-331b-4280-8a95-e92029fd16af, users, cloudron
              dn: cn=uid-0430c072-331b-4280-8a95-e92029fd16af,ou=users,dc=cloudron
              objectclass: user
              objectclass: person
              By local IP:
              # ldapsearch  -v -c -x -b "ou=users,dc=cloudron" -D "cn=admin,ou=system,dc=cloudron" -W -H ldaps://192.168.10.10:636 "cn=uid-13f9d18f-afd2-4c41-b78d-f2a32c0a3e18,ou=users,dc=cloudron"
              ldap_initialize( ldaps://192.168.10.10:636/??base )
              ldap_sasl_bind(SIMPLE): Can't contact LDAP server (-1)
              Wrong cert for the local IP?
              Also I noticed that if I save Directory Server configuration several times, multiple duplicate rules added to iptables:
              -A PREROUTING -p tcp -m tcp --dport 636 -j REDIRECT --to-ports 3004
              nebulonN girishG 3 Replies Last reply
                # extended LDIF
                # LDAPv3
                # requesting: ALL
                objectclass: user
                objectclass: person
                By local IP:
                nebulonN Away
                nebulonN Away
                @vladimir-d certs are issued for domain names, in this case for your my.domain.com and not the IP address. So depending on if your client accepts a mismatch in connecting hostname and the hostname mentioned in the cert, using the raw IP will fail.
                Is there any specific reason to use the IP (and also the intranet one apparently) instead of the domain name?
                  # extended LDIF
                  # LDAPv3
                  # requesting: ALL
                  objectclass: user
                  objectclass: person
                  By local IP:
                  As @nebulon said, IP addresses cannot have a valid certificate. But (for whatever reason), you really want to use an IP, you can export LDAPTLS_REQCERT=never which disables the cert check for ldapsearch and friends.
                    vladimir.dV Offline
                    vladimir.dV Offline
                    vladimir.d
                    Yes, sorted that with passing a flag to switch the cert validation off to ldapsearch.
                    LDAPTLS_REQCERT=never ldapsearch  -v -c -x -b "ou=users,dc=cloudron" -D "cn=admin,ou=system,dc=cloudron" -W -H ldaps://192.168.10.10:636
                    In fact, we need to connect various services to ldap not just ldapsearch, so apparently there is only one way out - we have to use a domain name.
                    Thank you @girish and @nebulon
                      # extended LDIF
                      # LDAPv3
                      # requesting: ALL
                      objectclass: user
                      objectclass: person
                      By local IP:
                      I was able to reproduce this, thanks for reporting. It's fixed in the next release - https://git.cloudron.io/cloudron/box/-/commit/d13905377c375823e7b6fd66bd248421544a1d2c .
                      The duplicate rules are harmless nevertheless.
