  2. Moodle
  3. cron + max_input are missing by default
Scheduled Pinned Locked Moved Solved Moodle
moodleinstallation
3 Posts 2 Posters 1.2k Views 2 Watching
  • JOduMonTJ Offline
    JOduMonTJ Offline
    JOduMonT
    It is normal that, by default, Moodle doesn't have a cronjob?
    The admin/cli/cron.php script has never been run and should run every 1 min.
    Also Moodle cry that I should adjust my max input in my php.ini
    ;max_input_vars = 1000
    max_input_vars = 5000
    Obviously, these are an easy job to do manually; but if these could be automated during the installation, that would be a +.
    girishG 2 Replies Last reply
    • JOduMonTJ JOduMonT
      @JOduMonT the cron is a bug, thanks for reporting. Making a new package.
        @JOduMonT Both issues are fixed in the latest package.
