  2. NocoDB
  3. Filesystem Mount inside Container
Scheduled Pinned Locked Moved NocoDB
20 Posts 5 Posters 13.9k Views 5 Watching
  • benborgesB
    benborgesB
    benborges
    wrote on last edited by benborges
    Im finding myself in the same situation, I have my volumes mounted as Filesytem volumes, but even with permissions set to Yellowtent, I can't cd into the folder or I can't access the file inside the volume directly.
    I get "no such file or directory"
    But by reading this thread, I see that the advice is to chown it to Cloudron user, not yellowtent, so Imma try that.
    edit: well actually, the "cloudron" user is the yellowtent user on the host
    so I'm not sure what else I can do to get this rolling.
    Cloudron volumes view :
    From cloudron nocodb app :
    from the terminal container :
    With nocodb :
    BenB
    benborgesB 1 Reply Last reply
    • benborgesB benborges
      With nocodb :
      benborgesB
      benborgesB
      benborges
      As you can deduce, I want to read that sqlite file that I symlinked inside /opt/amplifyukraine and then mounted as filesystem volume so that I can add it to the container, it all appears to work but the moment I want to get inside the mount and actualy read the file, or even just LS into the folder, I can't..
      BenB
        benborgesB
        benborgesB
        benborges
        I'm wondering if I'm doing anything wrong or if what i'm doing cannot be done ? and at the same time I'm so close to get it how I want, I hope I can do this with this static sqlite file
        Maybe I shouldn't have mounted these volumes from /OPT and instead used /MNT or /SRV to have these filesystem mounts, does it matter ?
        BenB
          benborgesB
          benborgesB
          benborges
          Well I don't know but /SRV with proper permissions (yellowtent) works !
          I can finally see the content of the mount from the file manager.
          Maybe my problem is that I have to remount these volumes now that I changed ownership ?
          anyway, will try some more but this is a good step forward : ca9e622f-501b-4213-9d26-96599a11f666-image.png
          BenB
            benborgesB
            benborgesB
            benborges
            it's working !!
            I have nocodb reading this sqlite file and I can add layers of data on top while tg-archive is feeding new posts to the base itself,
            tldr :
            I have tg-archive running at /home/tg-archive/
            there I have a site folder that sync from telegram and output static sites.
            But I wanted to be able to have research, filtering, sorting with a simple front-end, that's where nocodb comes in.
            All I did was a clean symlink for yellowtent user/group from /home/tg-archive/sites/telehunt/ to /srv/telehunt/
            ln -s /home/tg-archive/sites/telehunt/ /srv/telehunt
            sudo chown -h yellowtent:yellowtent telehunt/ inside /srv/
            then I added this as filesystem mount in the volumes view pointing to /srv/telehunt/ with name telehuntsrv
            next I attached this volume to the nocodb container, when it's running, I added the path to the sqlite file /media/telehuntsrv/data.sqlite
            And voila
            BenB
              it's working !!
              tldr :
              And voila
              benborgesB
              benborgesB
              benborges
              Oh my god I love cloudron ! Solved !
              BenB
              SupaikuS 1 Reply Last reply
                SupaikuS
                SupaikuS
                Supaiku
                @benborges Thanks, this helped me!
                Symlinked from my SATA HDD mount on the filesystem into the /srv/ directory and chowned and it works.
                Not sure why it only works into the /srv/ directory though. Curious about that...
                • SupaikuS Supaiku referenced this topic on
                • SupaikuS Supaiku
                  @Supaiku said in Filesystem Mount inside Container:
                  currently, the list of directories that can be mounted into apps is hardcoded. This is done for basic security. Like you wouldn't want /home or /etc of host mounted into app by mistake or maliciously.
                    SupaikuS
                    SupaikuS
                    Supaiku
                    @girish that makes sense - I didn't see anything about this list or how it's hardcoded in the Docs, did I just miss that or is it not mentioned there?
                    • SupaikuS Supaiku
                      @Supaiku indeed, it's not listed anywhere in the docs. I will get that sorted out.
                      edit: added note in https://docs.cloudron.io/volumes/#filesystem
                      SupaikuS 2 Replies Last reply
                        SupaikuS
                        SupaikuS
                        Supaiku
                        @girish w00t! 🙂
                        Interestingly in my case I was trying to add something mounted under /media/ but it wasn't working. Perhaps something else was amiss there or it was updated since.
                          SupaikuS
                          SupaikuS
                          Supaiku
                          @girish I actually discovered that what I thought had worked didn't, the symlinks to the mounted drive do not work (I had accidentally just used directories inside of directories that weren't properly symlinked, and there are also symlinked directories which do work), they give the same "hostPath does not exist" error even inside /srv/ (and also inside their non-symlinked mount point inside media)
                          Why wouldn't these mount points be visible to cloudron?
                          /etc/fstab line:
                          UUID=29608fe1-0f6c-4326-b10f-94750492ba49 /media/r00buntu/Data ext4 defaults,users,rw,auto 0 0
                          As you can see it's mounted within /media
                          But it's also symlinked within the srv directory for example: /srv/rzn-bk/backups-sym and when trying to add that it won't add. Same goes for just /srv/backups-sym
                          All host path does not exist...
                          nebulonN girishG 2 Replies Last reply
                          • SupaikuS Supaiku
                            /etc/fstab line:
                            @Supaiku have you tried to add a volume in Cloudron with the existing mountpoint option? The symlink as such will not work as Cloudron will resolve the mount point directly
                            • SupaikuS Supaiku
                              /etc/fstab line:
                              @Supaiku on Cloudron, the only way to expose paths from host into apps is to use Volumes.
                              If you want to manage the mount on host yourself, first add a Volume using File system (mountpoint) - https://docs.cloudron.io/volumes/#filesystem-mountpoint . If possible, I would actually use one of the "managed" mount types instead of editing fstab directly, but I don't know your setup.
                              After you have created the volume, you have to then "mount" this into whichever app(s) you want - https://docs.cloudron.io/apps/#mounts
                                SupaikuS
                                SupaikuS
                                Supaiku
                                wrote on last edited by Supaiku
                                @girish I also use the volume in my linux install on my home server for other services, so it's mounted when the server boots up
                                trying to add it via the filesystem mountpoint results in the same error:
                                It is a EXT4 formatted disk, so I tried that one and got this:
                                Perhaps because it's already mounted?
                                I'll find an extra drive and hook it up and see if I can get it work with something fresh.
                                girishG benborgesB 2 Replies Last reply
                                • SupaikuS Supaiku
                                  There is a typo - it says /dev/diesk instead of /dev/disk . Could it be that?
                                  • SupaikuS Supaiku
                                    benborgesB
                                    benborgesB
                                    benborges
                                    @Supaiku When I needed filesystems mount a few months ago (on top of sshfs mounts) I remember I struggled quite a bit to mount filesystems folders, but one thing worked :
                                    • Create /srv/YourFolder
                                    • Symlink that folder to the folder you want on the filesystem
                                    • mount that path inside Cloudron
                                    That's how I read SQLite files from other apps from say NocoDB or other cloudron apps.
                                    BenB
                                    robiR SupaikuS 2 Replies Last reply
                                      @girish is this documented? app to app mounts?
                                        SupaikuS
                                        SupaikuS
                                        Supaiku
                                        @benborges I did try that, but for some reason it wasn't working with the folders on other mounted drives.
                                        I just went with the mount point mounts on a new hard drive, but it is odd I couldn't get it to work.
                                          SupaikuS
                                          SupaikuS
                                          Supaiku
                                          @girish 😥 could be - at least for the uid one, but not for the file one
                                          I just put another disk on that was fresh and used that with the filesystem mount.
                                          • T THI_Staff referenced this topic on
                                          • benborgesB benborges referenced this topic on
