Rotation of AWS IAM credentials
Following the docs here, I have cloudron up and running with AWS route53 and all appears to be working fine. The problem comes every time I need to rotate my AWS IAM keys. Currently I am manually updating these credentials and saving them through the web UI.
Based on https://docs.cloudron.io/api.html#tag/Domains/paths/~1domains~1{domain}/put it appears that I can do this through the API, do you by change have an example of the Config parameter in use?
Im guessing the best approach to this would be to install the AWS cli on the cloudron server and call it via cron to execute the credential rotation and call the API to update the domain. Thoughts? I just want to make sure I am not missing an obvious configuration option you already have to handle such issues.
@prusaman the
configis an object withaccessKeyIdandsecretAccessKey.It might be easier to just create long(ish) keys which are scoped to just route53 only and that too only for the specific domain. See the IAM policy example here - https://docs.cloudron.io/domains/#route53-dns
@prusaman the
My assumption is something along the lines of
{ "provider": "route53", "config": {"accessKeyId":"AKIAXXXXXXX", "secretAccessKey":"XXXXXXXXXXXXXX"}, "wildcard": true, "zoneName": "my.zone.name", } -
@prusaman something like this:
{ "domain":"domain.com", "zone": "domain.com", "provider":"route53", "config": { "accessKeyId":"AKIAxx", "secretAccessKey":"yy" }, "tlsConfig":{ "provider":"letsencrypt-prod","wildcard":true } } -
@girish Im getting the following:
curl -k -X PUT -H 'Content-Type: application/json' -H 'Authorization: Bearer APIKEYHERE' --data '{"domain":"sub.domain.tld","zone": "sub.domain.tld","provider":"route53","config": {"accessKeyId":"AKIA","secretAccessKey":"XXXXX"},"tlsConfig":{ "provider":"letsencrypt-prod","wildcard":true }}' https://my.sub.domain.tld/api/v1/domains/sub.domain.tld<!DOCTYPE html> <html lang="en"> <head> <meta charset="utf-8"> <title>Error</title> </head> <body> <pre>Cannot PUT /api/v1/domains/sub.domain.tld</pre> </body> </html>But I get the following with:
curl -k -X GET -H 'Content-Type: application/json' -H 'Authorization: Bearer APIKEYHERE' https://my.sub.domain.tld/api/v1/domains{ "domains": [ { "domain": "sub.domain.tld", "zoneName": "sub.domain.tld", "provider": "route53", "config": {} } ] }Any ideas? Im sure Im just not constructing the call correctly.
@prusaman said in Rotation of AWS IAM credentials:
I got the path wrong. Send POST request to
https://my.sub.domain.tld/api/v1/domains/sub.domain.tld/config. I double checked that it works. -
G girish marked this topic as a question on
G girish has marked this topic as solved on
