  2. Matrix (Synapse/Element)
  3. federation tester not working on base domain
Scheduled Pinned Locked Moved Solved Matrix (Synapse/Element)
10 Posts 4 Posters 3.9k Views 4 Watching
  • RazielKanosR Offline
    RazielKanos
    i am getting this when i run the test on matrix.domain.com:443
    but when i try to run the test just with domain.com:443 i just get a blank page, same with just domain.com
      Which federation tester is this so we can try to reproduce it.
        @nebulon I'd guess https://federationtester.matrix.org/
        I think https://federationtester.matrix.org/#chat.uniteddiversity.coop used to work, but I'm currently getting errors there too (oh, probably because that is my install of Element, not my Matrix Synapse install... but actually get the same error at https://federationtester.matrix.org/#matrix.uniteddiversity.coop too - aha - but https://federationtester.matrix.org/#uniteddiversity.coop )
        works fine!)
        @RazielKanos said in federation tester not working on base domain:
        Try without https:// and without the trailing / too
        RazielKanosR 1 Reply Last reply
          Hm our instance seems to work https://federationtester.matrix.org/#cloudron.io to be honest I am not sure what the two errors from @RazielKanos indicate or try to tell us.
            works fine!)
            RazielKanos
            @jdaviescoates
            I did that - and get a blank page
              RazielKanos
              @nebulon
              I sent you my configuration for the well-known locations via PM, should all be set up correctly, not?
                so in Cloudron the well-known input for matrix is in our case matrix.cloudron.io:443 and that should be sufficient as far as I am aware of.
                • BrutalBirdieB Offline
                  Yes and No. Do you have anything installed under the bare domain?
                  See: https://docs.cloudron.io/domains/#well-known-locations
                  Note that Cloudron can respond to this end point only when an app is installed on the bare domain.
                  Means you must have SOME app at DOMAIN.TLD even if the matrix home is under matrix.DOMAIN.TLD
                  Did you do that?
                  Also works if you have the bare domain as an alias in for example an LAMP app.
                  That's how I do it.
                    RazielKanos
                    on my domain i have a wordpress page, so ppl can see something if they go there
                      RazielKanos
                      ok, got it fixed...
                      Cloudron told me to:
                      For federation to work, the delegation URI https://domain.com/.well-known/matrix/server must be configured. See the docs on how to do this.
                      but to get it working, I had to add:
                      Topic can be marked as solved 🙂
