  3. PicoCMS
PicoCMS
11 Posts 6 Posters 4.7k Views 6 Watching
    Simple markdown flatfile cms. http://picocms.org/
    A 1 Reply Last reply
      A
      A
      abargel
      @nebulon Easy:
      • install LAMP app.
      • upload a prebundled package into the "public" folder.
      • decompress it.
      • set the PHP version to 7.4
      Done. In case anyone searches for info here like I did...
      humptyH robiR L 3 Replies Last reply
      • A abargel
        @nebulon Easy:
        • install LAMP app.
        • decompress it.
        humptyH
        humptyH
        humpty
        @abargel turns out you can add pico to nextcloud too
        https://apps.nextcloud.com/apps/cms_pico
        • humptyH humpty
          A
          A
          abargel
          @humptydumpty Yes, that is also an option. I preferred to keep it standalone and "stupidly simple".
          humptyH 1 Reply Last reply
          • A abargel
            humptyH
            humptyH
            humpty
            @abargel I hear you. I’m interested in their html output plugin, hoping I can export static websites to use in a surfer app.
            • humptyH humpty
              Super Fan
              @humptydumpty see also https://getpublii.com/ for that use case.
              I think I came across it via a post @timconsidine made on here.
              I used it for https://wiki.safejust.space/ just to play around šŸ™‚
              • A abargel
                @nebulon Easy:
                • install LAMP app.
                • decompress it.
                @abargel said in PicoCMS:
                Why did you need to do this?
                It seems to work just fine with a new install of LAMP and PHP 8.1 .
                  A
                  A
                  abargel
                  @robi After decompressing the file in my public folder, if I just restart the app (which I should probably have included in my list, anyway), it remains stuck on the starting process and the logs say:
                  Which I had read about on the Github page.
                  Downgrading PHP to 7.4 is an easy fix. One can also use the "alpha" release that they mention, I suppose (haven't tried). Which package were you using?
                  • A abargel
                    @abargel I got the latest, alpha.
                    • A abargel
                      @nebulon Easy:
                      • install LAMP app.
                      • decompress it.
                      CA Maintainer
                      @nebulon Easy:
                      • install LAMP app.
                      • decompress it.
                      Thank you very much for taking the trouble to explain this. Not only does it show how to solve the problem, it cheers people up that you can do things easily on Cloudron. It also encourages people to give Pico a try and other similar applications like that.
                      • L LoudLemur
                        @nebulon Easy:
                        • install LAMP app.
                        • decompress it.
                        A
                        A
                        abargel
                        @LoudLemur Thank you for the support. I've been using Cloudron for about 6 months now, and am starting to figure out (some simple) custom apps. This one seems like it would be easy to package properly, doesn't it?
                        I've also had some success with Leantime and Tiddlywiki, if anyone is interested.
                        With your input, this post could be even better šŸ’—
