  2. Package development
  3. Multi-Stage Dockerfiles
10 Posts 6 Posters 4.9k Views 6 Watching
  • KubernetesK
    KubernetesK
    Kubernetes
    Dear @staff ,
    I would like to request to accept Multi Stage Dockerfiles for Cloudron packages.
    As at the end only the generated Docker Image is what is relevent, it should be accepted if a Multi Stage Dockerfile has been used to build the Cloudron Package Docker Image.
    IMHO this would speed up package creation a lot.
    Best,
    Mike
    girishG timconsidineT LanhildL 3 Replies Last reply
    • KubernetesK Kubernetes
      Dear @staff ,
      Best,
      Mike
      @Kubernetes should be OK. We tried this out the typebot package and it's been working out OK so far.
      As always, the main thing is that all the images must be pinned to a tag. The primary image should be the Cloudron base image.
      KubernetesK 1 Reply Last reply
        KubernetesK
        KubernetesK
        Kubernetes
        @girish okay, so that means, this example of a Dockerfile would be acceptable?
        FROM node:20-alpine as build-stage
        WORKDIR /app
        COPY package*.json ./
        RUN npm install
        COPY . .
        RUN npm run build
        FROM cloudron/base:4.2.0@sha256:46da2fffb36353ef714f97ae8e962bd2c212ca091108d768ba473078319a47f4 as production-stage
        WORKDIR /app
        COPY --from=build-stage /app/node_modules ./node_modules
        COPY --from=build-stage /app/package.json ./
        COPY --from=build-stage /app/dist ./dist
        COPY --from=build-stage /app/server.js ./
        COPY --from=build-stage /app/static-server.js ./
        COPY --from=build-stage /app/api ./api
        EXPOSE 18966
        CMD ["npm", "start"]
          Dear @staff ,
          Best,
          Mike
          @Kubernetes good suggestion šŸ‘
          If I see something interesting to package, but then see it's a multi-stage build, I run a mile on the basis that it will too complex to convert into a single-build model.
            @Kubernetes yes, looks good!
            • klawitterbK
              klawitterbK
              klawitterb
              I’m using multi stage dockerfiles for my projects, works like a charm. Only for final stage I use the cloudron base image.
                Dear @staff ,
                Best,
                Mike
                LanhildL
                LanhildL
                Lanhild
                @Kubernetes That's what I've done for the GROWI package so far, and apart from the things left to do, it works really well and makes things easier
                • L
                  CA Maintainer
                  From Arya:
                  "Multi-stage Docker files are a way to build Docker images in multiple stages, allowing you to create a more efficient and optimized final image. This is useful because it allows you to separate the build environment from the final runtime environment, removing unnecessary dependencies and reducing image size. This leads to faster build times, less vulnerability to security issues, and easier deployment of the final image."
                  • LanhildL
                    LanhildL
                    Lanhild
                    Bumping again for this one specific topic, using multi-stage Dockerfiles when possible for Cloudron packages makes building time substantially faster.
                      @Lanhild yup, we already started using multi-stage builds by now. For app store, you have to pin the images though. Using ":latest" is not good will have to be changed.
                      With your input, this post could be even better šŸ’—
