  2. MiroTalk
  3. Use Cloudron Logins for host protected settings
Scheduled Pinned Locked Moved Solved MiroTalk
mirotalk
47 Posts 9 Posters 11.9k Views 9 Watching
    I think a direct link is like a public link share unless the room is protected, so that might be expected on how the app is currently written
    mdc773M
    mdc773M
    mdc773
    @nebulon said in Use Cloudron Logins for host protected settings:
    even if i enable protection still cant use couldron account
    • mdc773M mdc773
      #42
      @mdc773 I think perhaps you're missing something here.
      If you're already logged into your Cloudron dashboard in the same browser you visit your MiroTalk app URL, it doesn't prompt for auth - it just magically checks if you're logged in and if you are just automatically logs you in.
      But if you visit the same URL in a private tab you should indeed get prompted to login to Cloudron.
      At least that's what happens for me.
      I am logged into my Cloudron dashboard, so when I visit my MiroTalk URL I arrive here:
      But if I visit the same URL in a private tab I get this:
      I also just double checked and if you try to visit a join URL of a meeting after the logged in person has left the meeting, it no longer works and you are presented with the login screen again.
      mdc773M 1 Reply Last reply
        mdc773M
        mdc773M
        mdc773
        @jdaviescoates awesome i was wondering how i did not think of this
        silly me
          @jdaviescoates good guess to resolve this quicker!
          • A
            A
            admeister
            Hi there,
            re: Mirotalk SFU 1.9.77
            I'm trying to configure Mirotalk SFU to only allow logged in Cloudron users to join a room.
            If I'm reading this thread correctly, I don't need to include any OIDC settings in the env file anymore - so this is what my env file looks like, attached.
            As the host, Mirotalk now (incorrectly) says that I am not logged in myself (even though I launched MiroTalk from my Cloudron admin dashboard), and then it asks me to login with the MiroTalk interface itself (and not the Cloudron login). When I attempt to use my Cloudron login details it says I have invalid credentials.
            So do I actually need to configure all the OIDC settings in the env file? If so, can I pls get some guidance on how to arrive at the exact settings needed?
            Thank you! 🙂
            Ads
            MiroTalkM 1 Reply Last reply
            • A admeister
              Hi there,
              Thank you! 🙂
              Ads
              MiroTalkM
              MiroTalkM
              MiroTalk
              App Maintainer
              #46
              @admeister said in Use Cloudron Logins for host protected settings:
              Simply remove all the old or unnecessary entries from your env file:
              Note: The parameter ALLOW_ROOM_CREATION_WITHOUT_HOST is not related to MiroTalk SFU.
              To explicitly configure MiroTalk with Cloudron OIDC Authentication (this is also the default behavior if not explicitly set), use the following environment variables:
              OIDC_ENABLED=true
              OIDC_ALLOW_ROOMS_CREATION_FOR_AUTH_USERS=true
              • OIDC_ENABLED=true — Enables OIDC authentication.
              • OIDC_ALLOW_ROOMS_CREATION_FOR_AUTH_USERS=true — Allows all authenticated users via OIDC to create their own rooms.
              If you do not want to use OIDC authentication but still want to define your own user logins, you can disable OIDC and enable MiroTalk SFU internal Host Protection Mode:
              # Disable Cloudron OIDC
              OIDC_ENABLED=false
              # Host protection
              HOST_PROTECTED=true
              HOST_USER_AUTH=false
              # Define host users in the format:
              # username:password:displayName:allowedRooms (comma-separated)
              HOST_USERS="user1:pass1:user-1:*|user2@mail.com:pass2:user two:*|user3:pass3:user name:*"
              • HOST_PROTECTED=true — Enables Host Protection mode.
              • HOST_USER_AUTH=false — Disables additional user authentication beyond host users.
              • HOST_USERS — List of host users, with * allowing access to all rooms or specific room names separated by commas.
              ⚠️ After making changes, restart your MiroTalk instance for them to take effect.
              For a complete environment configuration, check the .env.template file:
              Full env example
              The environment variables are loaded in config.js and serve both as runtime configuration and documentation for additional features:
              Full config.js example
              • A
                A
                admeister
                wrote on last edited by admeister
                #47
                Thank you everyone for your responses.
                Realised that the solution was far simpler than I thought - I just needed to add a single line to the .env file:
                OIDC_AUTH_REQUIRED=true
                Thank you deeply to everyone working on Cloudron and all associated apps... I'm in awe of this community!
                Ads
