  2. MiroTalk
  3. Use Cloudron Logins for host protected settings
Scheduled Pinned Locked Moved Solved MiroTalk
mirotalk
47 Posts 9 Posters 13.0k Views 9 Watching
    In that case maybe just try to reinstall the app so it gets provisioned with a fresh config.js if the migration during update didn't work out for some reason.
    • C
      C
      cvachery
      The reinstall doesn't change the content of this file.
      And I don't see how it could be looking at the docker file but maybe I'm missing something
        To be clear the file you were linking from the package repo is a wrapper for config.js which will read values from /app/data/config.js and merges it with Cloudron specific ones. Maybe this is where the confusion comes from?
        • C
          C
          cvachery
          Yes I got that it's a wrapper but this wrapper is never used neither in the dockerfile or start.sh so I don't get when this merge is done
            That file overwrites the upstream config.js in https://git.cloudron.io/cloudron/mirotalksfu-app/-/blob/main/Dockerfile?ref_type=heads#L13 and then loads the one in /app/data/config.js and then patches up the process internal config object. Only very specific config options are copied over though. For auth it is only those three essentially https://git.cloudron.io/cloudron/mirotalksfu-app/-/blob/main/config.js?ref_type=heads#L20
            But maybe to take a step back, whatever is specified regarding oidc in the /app/data/config.js will get overwritten during runtime. So that is probably not the root cause of the issue you are facing.
            • C
              C
              cvachery
              You are right I misread the Dockerfile, thanks for pointing this out!
              Maybe it would it be easier to have an example of a config.js file in the documentation.
              I guess I'm not the only one failing to configure it 😕
              Do I need to create an OpenID Connect Provider in my Cloudron user directory?
              • jdaviescoatesJ
                #27
                @cvachery I'm confused by this thread.
                You shouldn't need to configue anything.
                Just select the relevant User management settings when installing and Cloudron sets it all up, no? 🤔
                • C
                  C
                  cvachery
                  wrote on last edited by cvachery
                  #28
                  I did the same but ticked Allow all users from this Cloudron
                  Thing is @jdaviescoates by default anyone can create/join a room. But I want to restrict room creation to logged in users and anyone can join with the link.
                  And when activating those parameters is when problems arise.
                  jdaviescoatesJ 2 Replies Last reply
                  • C cvachery
                    • C cvachery
                      @cvachery said in Use Cloudron Logins for host protected settings:
                      Ah, right. That ought to be default when choosing Cloudron user management, but I guess it isn't.
                      • MiroTalkM MiroTalk
                        @avatar1024 said in Use Cloudron Logins for host protected settings:
                        Otherwise, while guest cannot enter the app base domain without a login, they can still create rooms freely by creating a url: mirotalkappprefix.mydomain.com/join/roomname
                        @MiroTalk is that behaviour intended?
                        Not a behaviour intended! I'm considering a refinement where guests are only allowed to join specified rooms that have already been created by authenticated users. This approach might offer better control and security. Will be released in the next version.
                        C
                        C
                        cvachery
                        Thanks to @MiroTalk in the latest version it works and the config is nearly perfect
                        Only issue is still one identified erlier that anonymous users can create room if they go to the specific URL
                        @MiroTalk said in Use Cloudron Logins for host protected settings:
                        MiroTalkM 1 Reply Last reply
                        • C cvachery
                          MiroTalkM
                          MiroTalkM
                          MiroTalk
                          App Maintainer
                          Should be fixed in both MiroTalk P2P v.1.3.79 & MiroTalk SFU v.1.5.80. Cheers.
                          T 1 Reply Last reply
                            Both packages are updated also now.
                              T
                              T
                              Teiluj
                              #34
                              Yeah I am still having issue with this / cannot figure out the correct settings to prevent anonymous user room creation.
                              Basically, I am trying to limit room creation to registered Cloudron User, but still keep the possibility for anonymous users to join a room once created.
                              At the moment, my MiroTalk SFU app has its cloudron setting access control set to "Only allow the following users and groups".
                              I do have a custom config.js with the following:
                                  host: {
                                          Host Protection (default: false)
                                          To enhance host security, enable host protection - user auth and provide valid
                                          usernames and passwords in the users array.
                                      protected: true,
                                      user_auth: false,
                                      users: [
                                              username: 'username',
                                              password: 'password',
                                              username: 'username2',
                                              password: 'password2',
                              Yet room creation is still allowed for anonymous users.
                              I could set user_auth to true and provider "provide valid usernames and passwords in the users array." as mentioned in the config.js comment, but my understanding is that this will void/conflict with the cloudron OIDC integration.
                              Of course, I am likely missing something so I am wondering if anyone got this working properly and if/when so, what are the proper settings for preventing room creation by anonymous users.
                              Many thanks,
                              • T Teiluj
                                    host: {
                                        protected: true,
                                        user_auth: false,
                                        users: [
                                Many thanks,
                                MiroTalkM
                                MiroTalkM
                                MiroTalk
                                App Maintainer
                                @Neiluj If you have OIDC enabled, you can safely remove the entire host: { ... } section from your configuration. Simply rely on OIDC for authentication, and let me know if everything works as expected. Thank you!
                                  @Neiluj I just tried this here also with MiroTalk SFU and without changing the app configs manually, just install the app with Cloudron usermanagement enabled and then only authenticated users can create meetings, while everyone can join them with the share link.
                                  mdc773M 1 Reply Last reply
                                    mdc773M
                                    mdc773M
                                    mdc773
                                    @nebulon said in Use Cloudron Logins for host protected settings:
                                    cant login when i follow your direction
                                      was the app installed with Cloudron usermanagement? If so do you see an error somewhere?
                                        mdc773M
                                        mdc773M
                                        mdc773
                                        @nebulon Yes cloudron user management was selected. Wired now when i vist a room and does not prompt the user auth just lunches the room: /
                                          I think a direct link is like a public link share unless the room is protected, so that might be expected on how the app is currently written
